Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. May 17, 2025 at 6:02 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I'm a big believer in isolation valves too. :fistbump:
    All my years in industry I don't ever remember once saying "I wish they hadn't included these valves/unions/extra ports".
    I do remember saying "why the :censored: couldn't the :censored:, :censored:, :censored: included just one :censored: whatever as I was having what should have been an simple job turning into an epic pain in the @$$. :annoyed:
  2. May 17, 2025 at 6:14 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I've got valves everywhere with more to go once I finish replacing all the old copper in the house. Mostly for repair, but if something happens when I'm not home someone else can shut that affected area off and still use the rest of the system. The 1/2 bath I added you can isolate the water there. Even the ice maker for the fridge I have a valve in the basement along with the one behind the fridge. If I'm at work I don't expect mother to be able to pull the fridge out to shut the water off if SHTF. Go to the basement and boom, valve.
    When I was redoing the water softener system I did place a tee off the filter to go to the hose bibbs for just regular water. Not that you get much salt in the water out of modern softeners, but a trace. The front hose bibb is fed off the rainwater cistern while the bibb at the back of the house is off the well. It seems like a complicated system I've done, but doesn't take much to figure it out.
  3. May 17, 2025 at 6:24 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    There was a water leak in one of the 10 story buildings on campus. There wasn't a shut off valve to isolate the floor so they had to drain the entire building. They added shut offs when the repair was made.
  4. May 17, 2025 at 6:27 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    In completely other news, trying to makes heads or tails of the London Underground system when you're not used to using public transportation is proving difficult. :laugh:
    wee, NoOne, six5crèéd[OP] and 8 others like this.
  5. May 17, 2025 at 6:32 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    At the way back job we had a plumbing firm who did all of the major production installs.
    The foreman, who was there since day one, told me:
    "We spec out a job including isolation valves & extra ports so we can add equipment at a later time - quickly and at a lower cost.
    They (management) reject the proposal wanting a lower up front cost so we remove the extras.
    6 months later we are adding the equipment and have to drain the system, add valves and ports to do the job."
    :ballchain:
  6. May 17, 2025 at 6:32 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  7. May 17, 2025 at 7:55 PM
    Gen1TacoLady
    Gen1TacoLady Local favorite
    Pond Princess
    Washington County, MD
    '95 Red Tacoma
    Follow the colors. :thumbsup:
  8. May 17, 2025 at 8:43 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    MIND THE GAP!
    I’m not sure how you do with tech but I found the apps are very convenient for transportation versus traditional maps. The tube system in London is complex and detailed for sure. “TfL Go” I believe is the app.
  9. May 17, 2025 at 8:45 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    I keep coming across Citymapper so I have that one installed.
  10. May 17, 2025 at 8:48 PM
    Clark27
    Springfield, MA
    2015 Lexus GX460
    I remember one was particularly convenient. You could just enter where you were and where you wanted to be, it would put out the exact trains and stops you needed.
  11. May 18, 2025 at 2:17 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Morning all have a great Sunday
  12. May 18, 2025 at 2:43 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Good morning everyone, I hope you have a pleasant Sunday :hattip:
  13. May 18, 2025 at 6:15 AM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    Good morning guys. Enjoy your Sunday
  14. May 18, 2025 at 11:54 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Good afternoon friends! Hope Sunday has been good so far, have a blessed rest of the day :hattip:
    PzTank, POOLGUY, RustyGreen and 3 others like this.
  15. May 18, 2025 at 11:58 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    We didn’t start this project until after 3:00.
    All I was gonna do is dig where the hydrant would be. Once I realized the ground was moist to about 30” I said I’ll be back and went and got the skidsteer :D
    The fork worked pretty good, it at least loosened where we needed to dig :thumbsup:
    PzTank, mit88, POOLGUY and 6 others like this.
  16. May 18, 2025 at 12:45 PM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    I saw a small trencher attachment that operated off of a chainsaw.. I saw it on Instagram though so I don't have a current link to it or anything. Seems handy for small projects. though
  17. May 18, 2025 at 1:19 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    in clay and root-infested digging paths, i've used a 24" 9tpi pruning blade on a sawzall for that before. also used a hammer drill as well...
    always fun to need to explain to the boss what's taking so long when we're carving clay out like year-old ice cream.
  18. May 18, 2025 at 2:10 PM
    Tacoma Mike
    Southern Maine
    My thank you project is done.
    Came out pretty good.
    Lot better than this
  19. May 18, 2025 at 3:19 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Amazing transformation !:transformer:
    Are they solid or is there a covering and a core?
  20. May 18, 2025 at 4:12 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Well, all our plants and trees were looking good. Until....20250518_170702.jpg
