Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Jul 24, 2025 at 5:31 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  2. Jul 24, 2025 at 6:29 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Yeh it's got a better chance of boiling than freezing down here.
    On a totally unrelated note, we have eye wash stations all over the place at every facility across the space center. My safety guy yesterday told me OSHA says it's acceptable for that water to be 100degrees F max for use:eek:. So when it's a 108 heat index, they have to put up canopys over top these outdoor stations in case they get used.
    :rofl::rofl:
    Cwopinger, soundman98, mit88 and 7 others like this.
  3. Jul 24, 2025 at 6:32 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  4. Jul 24, 2025 at 6:37 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    They put a new heat pump in my boss man's office a couple years ago. Yesterday he had his doors open, I ask him why. He said his air wasn't working. The unit is above his office so I went and looked at it. The pan was slap full of water. I pumped some into the pump and it sent it out, so I got enough out to make it come back on.
    About that time the 2 guys showed up to work on it, told them what I done they checked some stuff and said they couldn't figure anything out about it.
    They are back :popcorn:
  5. Jul 24, 2025 at 6:44 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did you unplug the drain line?
    If the pan is full of water, the float switch trips and shuts down the unit.
  6. Jul 24, 2025 at 6:46 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I pumped enough water out of it to get it away from the float switch. I quit messing with it when it came back on and then the guys showed up to look at it.
    For some reason the pan was full, the pump was empty. Not sure why the water went into the pan and not the pump. Pump worked fine when I pumped water into it.
    soundman98, NoOne, mit88 and 6 others like this.
  7. Jul 24, 2025 at 6:51 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
  8. Jul 24, 2025 at 8:49 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  9. Jul 24, 2025 at 8:52 AM
    koditten
    Kirk
    Central Michigan
    Are you using the MM250 to glue these parts together?
    I watched my brother in law weld his prescription metal frames on his glasses back together with mine.
    soundman98, NoOne, PzTank and 4 others like this.
  10. Jul 24, 2025 at 8:54 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I used the Econo Tig on these :)
    NoOne, PzTank, RustyGreen and 4 others like this.
  11. Jul 24, 2025 at 9:10 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  12. Jul 24, 2025 at 9:13 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
  13. Jul 24, 2025 at 10:57 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    @koditten Check this out. They looked at it again today cause the pan had more water in it. Their fix, put a cup under the overflow :facepalm:
    That tells me the drain going to the pump is clogged and the overflow is doing it's job, I would think. The cup has about 2" of water in it.
    POOLGUY, soundman98, NoOne and 6 others like this.
  14. Jul 24, 2025 at 11:21 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    I thought it was a target
  15. Jul 24, 2025 at 11:40 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Somebody said OSHA!!!! :rofl::rofl::rofl:
  16. Jul 24, 2025 at 11:44 AM
    mit88
    Planet earth
  17. Jul 24, 2025 at 12:08 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Who are these guys, handymen...o_O
  18. Jul 24, 2025 at 12:10 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    They must be handsome.
  19. Jul 24, 2025 at 12:12 PM
    wilcam47
    Will
    Bourbon state
    :rofl:
  20. Jul 24, 2025 at 12:13 PM
    wilcam47
    Will
    Bourbon state
    Thats like putting traffic cones in front of a guardrail instead of fixing it...(they do that here):anonymous:
