Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    27.8%
  2. Hand(s)
    30.6%
  3. Cup
    19.4%
  4. I don’t rinse
    22.2%
  1. Aug 7, 2025 at 7:42 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Well fellers, I'm knackered, got home at 9:30.
    Started with this. There is a bush under there - covered with grape and some flimsy weedy things all around the perimeter, they pull out of the ground easy.
    ...several hours later...
    You can see the bush on the bottom, still lots of grape on the top.
    On the left you can see the brush pile that was buried in there, about 1/4 of what I started with. Behind the pile is another butt ton of the weedy things.
    The new 6.5hp engine is very smooth and powerful compared to the old 5hp, quieter too. So powerful in fact that if something jams the shredder it will smoke the belt rather than stalling. :eek:
    It is also now sadistically good on gas -- "I'll just keep working until it runs out..."
    :ballchain:
    "Please run out..."
    The machine beats you up, larger pieces have to be fed at a controlled rate, the vibrations are tough on the ol' arthritis.
    It also randomly throws things at you as well. :laugh:
    These are the green weedy things I pulled, hundreds of them.
    I'll have to bring the chipper down here for larger stuff, there is much more to do, probably another nine hours or so more and it will be cleaned up. :annoyed:
    I don't think it will be tomorrow, I'll be hurting. :turtleride:
    koditten and wilcam47 like this.
  2. Aug 7, 2025 at 7:50 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :bowdown::bowdown::bowdown:
    RustyGreen[QUOTED] likes this.
  3. Aug 7, 2025 at 7:55 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The shredder was finished last week - there was no way I was going to try to do this on 90+ degree days.
    I went through a half gallon of water in 3 hours.
    wilcam47[QUOTED] likes this.
  4. Aug 7, 2025 at 9:18 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Just finished putting the rails up. This weekend I will cut and route the top rails and install the solar LED strip lights under the rail.IMG_4376.jpg
    williams63, koditten and wilcam47 like this.
