Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
Electrical outlet cover screws MUST be......
  1. Horizontal
    10.0%
  2. Vertical
    46.7%
  3. Not matching, ain't nobody got time for that
    16.7%
  4. Over torqued so the fake plastic cracks, then back off just a tad
    43.3%
Multiple votes are allowed.
  1. Mar 2, 2021 at 6:48 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Yep a teryx 750. Ran low on oil and needed a rebuild. Guy filled it with oil and wanted to try to get it to come out of hard starts and smoking. Was driving it and locked it up. Hopefully it’s still salvageable
  2. Mar 2, 2021 at 7:01 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  3. Mar 2, 2021 at 7:02 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    How you doing PJT?
  4. Mar 2, 2021 at 7:03 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Customer brought these two stainless valves in and wanted the fittings out. He said he broke his vice, he had a 2” wrench and told me how to get them out.....thanks :rolleyes:
  5. Mar 2, 2021 at 7:08 AM
    Plain Jane Taco
    USA
    Not bad for a rich, tall, good looking, well hung thunder stallion
  6. Mar 2, 2021 at 7:09 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I found a piece of chain 3’ 6” long and got 5 pieces with 6 links out of it. It’s for the rear of my bushhog I’m redoing. I’m thinking I need 60 more pieces so it should be 42’ :eek:
    My boss mans brother in law owns the local hardware store, when I did the front I needed 56 pieces, he made me cut them with his hydraulic jack cutter. It sucked.
    I’m going to get it and saw it, a lot quicker. I still have all the half links where I cut the others.
    Vmax88, TomTwo, RustyGreen and 5 others like this.
  7. Mar 2, 2021 at 7:10 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  8. Mar 2, 2021 at 7:12 AM
    Plain Jane Taco
    USA
  9. Mar 2, 2021 at 7:17 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Why???????? :confused:
  10. Mar 2, 2021 at 7:17 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Dragging this morning for some reason, may be time for a 3rd cup of coffee :D
  11. Mar 2, 2021 at 7:28 AM
    StayinStock
    StayinStock Pepsi > Coke
    Bob
    Missouri
    Yes I do
    Some
  12. Mar 2, 2021 at 7:54 AM
    My Name is Rahl
  13. Mar 2, 2021 at 8:45 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Wound up with 64 pieces out of 46’ 6”.
  14. Mar 2, 2021 at 8:46 AM
    cory02taco
    Cory
    Maine
    1A5478A5-0D32-4DD3-9E86-869EEECDAECC.jpg 304F4AE3-644A-4580-B315-06ED354DFB8A.jpg
    well would ya look at that.
    tacotoe, Vmax88, RustyGreen and 4 others like this.
  15. Mar 2, 2021 at 8:48 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    My guess, crank will need to be ground :D
  16. Mar 2, 2021 at 8:52 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Dragon ass as we call it :D
  17. Mar 2, 2021 at 9:05 AM
    cory02taco
    Cory
    Maine
    more than likely. theres a company called wrench rabbit that sells a rebuild in a box, everything from the crank up every bearing, seal, pistons and rings, so this crank will probably end up in the scrap pile.
    tacotoe, Vmax88, Wyoming09 and 6 others like this.
  18. Mar 2, 2021 at 9:07 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  19. Mar 2, 2021 at 9:24 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Exactly how everything I work on here at the house turns into. One little thing turns into a full on rebuild job. Knowing that it kinda scares me getting into a cheap beater soon...o_O
  20. Mar 2, 2021 at 10:54 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Hot job just came in. Boss said customer needs five of these sight glasses, one by Friday. I said I’ll have them all done before then o_O
    I think that’s his way of saying don’t be in a rush :)
    tacotoe, RustyGreen, Delta09 and 5 others like this.
