Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Oct 9, 2020 at 3:10 PM
    #1321
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  2. Oct 9, 2020 at 3:11 PM
    #1322
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Fargo Taco and wilcam47 like this.
  3. Oct 9, 2020 at 3:11 PM
    #1323
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Nice!
  4. Oct 9, 2020 at 3:14 PM
    #1324
    wilcam47
    Will
    Bourbon state
  5. Oct 9, 2020 at 3:48 PM
    #1325
    My Name is Rahl
    Saw this happening today and thought of you, Deeds. If you can't tell, there is pallets in the back of a sedan.
    Why aren't you using a SHCS? They are ASTM A574...:boink:
    Geez! :eek: I'd be afraid of looking too hard at those and having them brake!
  6. Oct 9, 2020 at 4:10 PM
    #1326
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    I know, right? I've watched one roll right off a table before, luckily I wasn't involved only witnessed it lol.
  7. Oct 9, 2020 at 4:15 PM
    #1327
    wilcam47
    Will
    Bourbon state
    wut? Details?
  8. Oct 9, 2020 at 4:37 PM
    #1328
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I like SHCS’s but the only thing is they rust on stuff like this.
  9. Oct 9, 2020 at 4:48 PM
    #1329
    DLRIII
    David
    Baton Rouge
    I thought I had posted one of these here before, these rings get welded to a disc. I was cutting the rings from a tube today.
  10. Oct 9, 2020 at 4:49 PM
    #1330
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    That tube & plate are pure quartz. It takes an oxygen/hydrogen large volumes of each) flame to melt/weld the pieces together.
    I worked at a university that had a glass shop where they did some quartz work. I'd visit when the tech had a job in quartz. The shop was small I could only stand to be in it for 10 or 15 minutes it was so hot; also had to have special glasses to see what was going on.
    DLRIII is a real artist and highly skilled.
  11. Oct 9, 2020 at 4:52 PM
    #1331
    DLRIII
    David
    Baton Rouge
    Absolutely, you nailed it. Thats the sort of shop I work in, except were the largest Quartz operation I've seen before. I've been in a couple tiny shops, with that kind of heat it sounds like a nightmare.
    Edit: thank you sir.
    six5crèéd[OP] and wilcam47 like this.
  12. Oct 9, 2020 at 5:02 PM
    #1332
    wilcam47
    Will
    Bourbon state
    Thats amazing! Is it similar to brazing copper pipes?
  13. Oct 9, 2020 at 5:16 PM
    #1333
    DLRIII
    David
    Baton Rouge
    No, not quite. Im not a metal welder but I believe its closer to that. As stated by @INBONESTRYKER we use hand torches to heat the glass and weld whichever surfaces were welding together. We do actually melt quartz rod into gap between the 2 edges to be welded, but it doesn't look like brazing.
  14. Oct 9, 2020 at 5:26 PM
    #1334
    wilcam47
    Will
    Bourbon state
    Interesting. Never really knew it existed, thats a lost art
    six5crèéd[OP] likes this.
  15. Oct 9, 2020 at 6:21 PM
    #1335
    My Name is Rahl
    :eek: I bet it made a tremendous noise.
    https://www.fastenal.com/product/fa...ize&showAll=Length&selectedAggregation=Length
    Not this. This is anACQ1000 hour coating. Plus, it adds a dry lubrication that cuts the needed torque down.
  16. Oct 9, 2020 at 10:56 PM
    #1336
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Regarding the couple of guys with pallets in their cars, I thought I was doing good getting 6 or so at a time in my Pilot for a pallet wall. Turns out I'm a lightweight! :laugh:
  17. Oct 10, 2020 at 4:51 AM
    #1337
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    @StayinStock thought you’d like these. One of our customers came in the store with a case of lures this morning and said where’s your son? He was brushing his teeth and when he finished he came up front. Customer said this is what I was telling you I make, pick you one out. He gave me one as well. He carves them from scratch and paints them :eek:
    Vmax88, alee891, tcjacado and 7 others like this.
  18. Oct 10, 2020 at 4:52 AM
    #1338
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Those are nice! I assume they're wood?
  19. Oct 10, 2020 at 4:53 AM
    #1339
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Yes sir, said he uses balsa wood :thumbsup:
    wilcam47 and StayinStock[QUOTED] like this.
  20. Oct 10, 2020 at 4:53 AM
    #1340
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    He does a good job!
