Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    26.1%
  2. Hand(s)
    34.8%
  3. Cup
    17.4%
  4. I don’t rinse
    21.7%
  1. Mar 23, 2021 at 6:27 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    1st time it’s been on in 20+ years.
    nagorb, RustyGreen, 80yotaguy and 9 others like this.
  2. Mar 23, 2021 at 6:29 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
  3. Mar 23, 2021 at 6:31 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I sent this to my stepson and his wife. They have a Irish Wolfhound
  4. Mar 23, 2021 at 6:39 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    nagorb, RustyGreen, CurtB and 5 others like this.
  5. Mar 23, 2021 at 6:48 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :anonymous:
    RustyGreen, tacotoe, T-yoda and 2 others like this.
  6. Mar 23, 2021 at 7:02 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :101010:
  7. Mar 23, 2021 at 7:04 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If the other wasn’t OSHA approved, this should be :eek:
    Don’t try this at home kids.
    Sig45, RustyGreen, tacotoe and 6 others like this.
  8. Mar 23, 2021 at 7:25 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Fun fact, those use a 69 (nice!) watt bulb for the 8" lens signals. We used to order them at the building supply I used to work at. People put lower wattage bulbs in them for indoor displays. Typically a 25 watt or so medium base appliance bulb. The new LED bulbs don't quite get the same effect, but a 2700K color LED would be close in a pinch. If you knew this information, disregard :laugh:
    RustyGreen, tacotoe, T-yoda and 4 others like this.
  9. Mar 23, 2021 at 7:27 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I'm learning about this, thanks for the info! I found a board to make it cycle.
    https://www.ebay.com/itm/Traffic-Li...annel-Arrows-Crosswalk-Dragstrip/254534317823
    RustyGreen, buyobuyo, tacotoe and 5 others like this.
  10. Mar 23, 2021 at 7:30 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Alot of guys use old industrial timers and contactors that went in control panels. Most can be had for free. Takes a little bit of industrial wiring knowledge, but relatively easy. We did this in my industrial controls class a while back. Not as quick and simple as a pre-made board, but I like tinkering.
  11. Mar 23, 2021 at 7:31 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Good morning Shane
  12. Mar 23, 2021 at 7:31 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Clearly you've never spent any time in Asia! That exceeds standards simply by virtue of the fact that the insulation isn't stripped back two inches past the outlet, and I'll bet he even twisted the copper together too.
    RustyGreen, tacotoe, T-yoda and 3 others like this.
  13. Mar 23, 2021 at 7:33 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    morning
    so going to put the traffic light in the store?
  14. Mar 23, 2021 at 7:34 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I'm going to hang in the shop at the house.
  15. Mar 23, 2021 at 8:22 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  16. Mar 23, 2021 at 8:22 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    @6 gearT444E has one of those in his shop too. :cool:
  17. Mar 23, 2021 at 8:24 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    That is what I call Normal To many projects not enough life!!
  18. Mar 23, 2021 at 8:24 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    @six5crèéd been meaning to ask: where in NC are you? I’m hoping to get down to Uwharrie again at some point & was curious to see if you were on the way there. :D
  19. Mar 23, 2021 at 8:29 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I'm about an hour north of Uwharrie, it may be on your way depending on which way you go, you could bypass it or go right by me I guess is what I'm trying to say.
  20. Mar 23, 2021 at 8:34 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Usually go down 81 through Va to get there.
    hopefully I actually get to do a road trip at some point this year. If so I’ll hit you up. :thumbsup:
