Shop with spring compressor to change out King coils in OC?
Discussion in 'Southern California' started by 4wdExplorer, Nov 22, 2019.
  1. Nov 22, 2019 at 8:06 AM
    4wdExplorer
    4wdExplorer [OP] Well-Known Member
    Orange County, CA
    I want to swap my King coils from 700 to 650. I already have the 650 coils, just need to go into a shop with a good spring compressor that is open on the weekend. Preferably tomorrow Saturday.
    I will remove the coilovers from my truck myself and I can take them into the shop to change the springs out.
    Any shop in Orange County that can swap coils for me?
  2. Nov 22, 2019 at 8:17 AM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Didn’t know that you need to compress the spring to swap it. Thought you just need to lossen up the top with spanner, remove bottom piece and the spring slide through
  3. Nov 22, 2019 at 8:18 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Not on Tacoma shocks. They have too much preload for this method. Especially if he has 14” springs
  4. Nov 22, 2019 at 9:30 AM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    I see. Good luck
  5. Nov 22, 2019 at 9:44 AM
    4wdExplorer
    Orange County, CA
    Thats correct.
    I found a shop that can do it for me for $25 per coil, but they are not open on weekends.
    Bump!
  6. Nov 22, 2019 at 9:45 AM
    desertjunkie760
    Shane
    Check My Sig.
    That's not a bad price. If you were coming down to SD I would help you out but probably not worth the drive for you.
  7. Nov 22, 2019 at 11:06 AM
    4wdExplorer
    Orange County, CA
    Thank you. Yeah all I need is a shop with a good spring compressor since they are 700 lb coils. Shoot I can do everything myself if I had the spring compressor.
    SR-71A likes this.
  8. Nov 22, 2019 at 11:18 AM
    BVita
    BVita Mall Cruiser
    Shoot a message to @Bot_Chu, he is in Corona and should be able to help out for tomorrow. He has a spring compressor setup in his garage.
    whatstcp likes this.
  9. Nov 22, 2019 at 12:23 PM
    4wdExplorer
    Orange County, CA
    Thank you I will try and shoot him a PM.
  10. Dec 11, 2019 at 2:33 PM
    cheezoto
    cheezoto Well-Known Member
    1KD Diesel ACLB, Supercharged DCSB
    I have rented spring compressors from O'Reilly/Autozone in the past. Its free, they charge you a deposit, but it is refunded when you bring it back. If you can take the coilovers off yourself this is just as easy. Just make sure you have most all of the preload off before you take the main shaft nut off, otherwise it will shoot apart across your garage when the nut threads off.
  11. Dec 11, 2019 at 2:46 PM
    desertjunkie760
    Shane
    Check My Sig.
    hard pass. I'd pay someone to keep my life.
  12. Dec 11, 2019 at 2:55 PM
    cheezoto
    Haha, yeah its not that bad, but I feel you. Sometimes its better to let someone do it who has the tools and does it every day.
    There is also this option where you take the nut off the shaft while still on the truck and then let the lower arm droop down slowly to let the spring extend.
    https://www.youtube.com/watch?v=5E6u7dC7EHg
