short antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by inouk, Mar 15, 2011.
  1. Mar 15, 2011 at 5:55 AM
    inouk
    inouk [OP] Well-Known Member
    Hi,
    I have a Tacoma 2006.
    I have a interior parking at my work but the roof is low enough so that the antenna is always hitting ducts, pipes, cement, etc.
    I would like to know where I can find a shorter antenna, the one that would no go above the roof of the Tacoma ?
    Thanks!
  2. Mar 15, 2011 at 6:02 AM
    poynter
    poynter Well-Known Member
    Tony
    Somerset, KY
    05 Taco 4x4 SR5 TRD AC
    ebay has them. They come with different size studs so they are "universal"
  3. Mar 15, 2011 at 6:13 AM
    396tears
    396tears Well-Known Member
  4. Mar 15, 2011 at 6:18 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    There are also a few others who have shortened the OEM antenna a few inches by removing the little antenna ball, cutting the needed length off, then gluing/epoxying the ball back on.
  5. Mar 15, 2011 at 7:07 AM
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
  6. Mar 15, 2011 at 7:41 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
  7. Mar 15, 2011 at 7:49 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    How is the reception with that? Do you get out on the outer fringes to test it compared to your stock antenna?
  8. Mar 15, 2011 at 7:52 AM
    09blacktaco
    09blacktaco Well-Known Member
    The Rockies
    09 DC 4x4 TRD OR
    I have this one:
    http://www.cravenspeed.com/products/The-Stubby-Antenna.html
    I can tell you the reception suffers a bunch, but It does look nice and I listen to pandora/CD's all the time anyway.
  9. Mar 15, 2011 at 7:54 AM
    05 X-Runner
    Brett
  10. Mar 15, 2011 at 7:57 AM
    AbqTRD2010
    AbqTRD2010 Well-Known Member
    Michael
    Rio Rancho, NM
    '10 4x4 DblCab Long Bed Sport
    TRD FJ TeamTrail Blk Rims| BFG AT KO 265/75/16| TRD Cat-back Exhaust | TRD CAI | UNICHIP Installed| 5100 Billies @ 1.75 | Rear Leaft TSB & 1" Block| Grillcraft Satoshi Grill | Exclusive Element Light Bar w/ Hella 500FF | Aftermarket Black Headlights & Black LED Tail Lights| Preimium Hook Struts | SungTop LS Tonneau Cover |Black OEM Running Boards | Window Tint @ 20%| Blacked Out Emblems| Shortened Antenna | Flyzeye LED Interior Accent Lighting
    I removed the ball from my antenna, cut to desired length (roof line height) and placed the ball back on. I found a post on here that showed how to easily remove the ball. Place a set of pliers just behind the ball and tap the pliers with a hammer. This prevents you from trying to pull the ball off and scratching the ball. If you try to pull the ball off, it is near impossible and made of a soft metal that will easily leave deep scratches. It will take a few taps to knock the ball off. Make sure you are tapping the ball into a confined corner so you can find it when it comes off.
    Cut the antenna to the desired length. The cut location I chose was low enough that the antenna was thinner than the hole of the ball. To make sure I had a good fit and a clean finish I used the dermal to sand down the tip of the antenna and the black from the tip of the antenna. I filled the ball with solder and quickly placed back on the antenna. I used some extra solder around the bottom of the ball once it was placed on the antenna to ensure a tight fit. Then sanded down the solder to give the ball and the antenna a smooth finish. Finally I used flat black paint to repaint the antenna.
    The ball is nice and tight on the antenna. Also the antenna is now to a desired height so it no longer hits my garage door when driving in. I have not had any reception with any of the main local stations. There are a couple stations that I get very little static now when going under a bridge, in parking garages but no complaints about looks or reception.
    I intially bought one of those thick shorty antennas and I didnt like the look and also got a decent amouth of static.
  11. Mar 15, 2011 at 8:46 AM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Same here...I had an Antennex antenna for about two weeks and it got take out at the car wash. I chopped about 6 inches off my stock and put the ball back on. Reception seems about the same and no more scraping!
  12. Mar 15, 2011 at 8:47 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
  13. Mar 15, 2011 at 10:52 AM
    kb1jop
    kb1jop Well-Known Member
    Rick
    Springfield, MA
    2010 Barcelona Red 4WD DCSB 6-Speed SR5
    Factory Towing Package Factory Roof Rack OEM Bed Mat Trifecta Tri-Fold Tonneau SeatSaver Custom-Fit Seatcovers WeatherTech Custom-Fit Floor Mats Block Heater: http://www.metrotpn.com/ProductDetails.aspx?CollectionID=13&ProductID=191&SortIndex=9
  14. Mar 15, 2011 at 10:55 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    just cut it anything metal will transmit a signal i put a screwdriver in there to see and it worked as an antenna
  15. Mar 15, 2011 at 10:59 AM
    NLF
    NLF Well-Known Member
    Levi
    Minneapolis, MN
    '11 TRD Sport DC LB 4x4
    OME 884 & Bilstein 5100s @ 0, TSB Rear w/5100s, 20x8 Mamba M2 275/55/20 Geolander, Access Cover
    I bought the shorty from cravenspeed and it didn't work at all. Maybe I just got a bad one, but I was very disappointed as I liked the look.
  16. Mar 15, 2011 at 11:03 AM
    kb1jop
    Rick
    Springfield, MA
    It depends on how much you care about your radio reception. A straight whip on a vehicle is optimized at 30" for FM reception. I'm assuming the spiral wire around it is optimized for AM as best they can given the restricted space with which to work.
  17. Mar 15, 2011 at 11:05 AM
    LBCdan
    LBCdan I got tiger blood.. WINNING
    Dan
    Long Beach , CA
    2012 MGM DCSB TRD SPORT
    Pioneer 4000NEX , grab handle GPS mount, Bakflip tonneau, OME 885, Bilstein 5100s, Wheelers 1.5" AAL
    I went down to PepBoys and picked up a 13" rubber one... works fine. Oh yeah.. it was $8. :D
  18. Mar 15, 2011 at 11:09 AM
    taco221
    taco221 Well-Known Member
    Michael
    Cumming,GA
    08 Access Cab sr5 PreRunner.
    BHLM.Tinted tailights.Completely debadged.32% tint up front.Anytime foglights.Yellow foglights.Plasti dipped rear bumper.3 inch toytec lift.Duratracs and moto metal 955's,diff breather mod and colormatched grille/ and soon to be billet grille.
    I also have an AntennaX.It works great and was only $17.So much better than the factory antenna.This one never cathces on anything either,unlike the factory one.
  19. Mar 15, 2011 at 11:11 AM
    Hot Tamale
    Hot Tamale Well-Known Member
    Pat
    Henderson, NV
    2012 Access Cab 4x2
  20. Mar 16, 2011 at 4:35 AM
    396tears
    X X 3
    yep works great
    no difference from original:D
