Short Antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBazinga, May 28, 2014.
  1. May 28, 2014 at 5:36 AM
    TacoBazinga
    TacoBazinga [OP] Well-Known Member
    Dana
    Belchertown, Massachusetts
    2014 DCSB Manual, Magnetic Grey
    TRD Exhaust, Short Throw Shifter, Bead Lock Wheels, Undercover LUX cover, TWM Performace Desert Eagle shift knob
  2. May 28, 2014 at 5:57 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    If looks is all you're going for then it should be fine. You will most likely lose reception when you get any distance from the station.
    I cut my factory antenna to 14" and epoxied the ball back on top. Free and no noticeable loss in reception. That said.... I mostly listen to satellite radio or the USB.
  3. May 28, 2014 at 6:38 AM
    TacoBazinga
    Dana
    Thanks for the feedback! Looks mostly...I also listen to satellite and blue tooth, so reception isn't that big of a deal.
  4. May 28, 2014 at 6:42 AM
    RearViewMirror
    Craig Christ
    Then short of cutting your factory antenna you should be good. I like the looks of the one you linked.
