Short bed, air bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rockin&Chalkin, Mar 22, 2016.
  1. Mar 22, 2016 at 8:35 PM
    Rockin&Chalkin
    Rockin&Chalkin [OP] Well-Known Member
    Anthony
    2016 TRD O/R DCSB MGM
    been looking around haven't really been able to find anything specific. I plan on buying a bed tent and would like to get an air bed to use. What would you guys that have had short beds before, use or do? I'm half tempted to get a couple 2x4's and a piece of plywood to get up over the fender wells. Unless there is an air bed made for the short bed like the long beds. Any thoughts?
  2. Mar 22, 2016 at 8:36 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    2x4's and plywood would be a good start.
  3. Mar 22, 2016 at 8:39 PM
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    Sorry, I'm a long bed with a rtt but good luck with your search.
  4. Mar 22, 2016 at 8:39 PM
    2015whitetaco
    2015whitetaco Well-Known Member
    Pleasant Hill
    2000 Ford F-250 7.3 powerstroke 96 4runner POS
    http://www.autoanything.com/truck-tents/60A5319A0A0.aspx
    I have a long bed and used this one before i got a RTT and I loved it they make the short bed ones
    I had no issues with the long bed one and would recommend going this route instead of the ply wood because if you raise the mattress then the bed tent won't fit
    although I would recommend getting a Roof Top tent instead but they are a little more pricy
  5. Mar 22, 2016 at 8:47 PM
    Rockin&Chalkin
    Anthony
    See I have looked at the airbedz and it only shows the standard box, not short. I have considered roof top tent but like you said pricey between the cost of the tent and a rack to mount it on.
    2015whitetaco likes this.
  6. Mar 22, 2016 at 8:52 PM
    2015whitetaco
    Pleasant Hill
    That is weird I could have sworn I saw a short bed
    I would say just hold out till you can do a rack/shell/bars and an RTT
    I have an all pro rack I picked up off another TW member for 400 and then a Tepui Ayer For $875
    it is by far my favorite mod to the truck Easiest tent I have ever set up and also quickest
    I will never sleep in a ground tent again
    Plus you can keep your bedding in it if you want and it still folds up nicely
    and it keeps your bed free so your tent can be folded out without having to unpack the bed if you get to camp late
    mbmack1 likes this.
  7. Mar 22, 2016 at 8:55 PM
    mbmack1
    matt
    az
    SAVAGE silver '06
    The rack cost is pretty insignificant next to the rtt. The tent costs the real money. But I can tell you that I'd honestly never want to camp any other way again since I got mine. An rtt is the last tent you will ever buy. Its not Ozark trail "ripstop", its real, heavy duty ripstop material. If it rips you can sew it up and keep on trucking. You can customize them (I put an LED light strip in mine on a dimmer switch). You can feel the breeze through the trees at night. I could keep going but I don't feel like this is what ur looking for here so I'll stop. But if u have the $$- go with an rtt. U won't regret it.
  8. Mar 22, 2016 at 9:39 PM
    2015whitetaco
    Pleasant Hill
    I completely agree
    mbmack1[QUOTED] likes this.
  9. Mar 22, 2016 at 10:02 PM
    Rockin&Chalkin
    Anthony
    So do you guys just leave the tent on your rack? I just watched an install video and it seems pretty involved to install prior to heading out.
  10. Mar 22, 2016 at 10:05 PM
    2015whitetaco
    Pleasant Hill
    I just leave it on the rack 24/7
    i know guys that take it off after each trip and its not that bad I just personally don't have place to store it other then on the truck
    once the initial install is complete
    it is just 8 nuts and then ideally two people lift it off and you're done I have done it solo before and it wasn't bad just not ideal
    the initial install takes a while in comparison
  11. Mar 22, 2016 at 10:41 PM
    mbmack1
    matt
    az
    SAVAGE silver '06
    Agreed. The initial set up of a brand new rtt takes some work but once it's assembled the on and off the truck is minimal. Plus setup/breakdown at camp is 10-15 min max. And that's alone. If ur married or have a girlfriend who camps with you and u two practice a few times together you could probably do 5 min each way. And I love not having to haul my sleeping bags and pillows in the cab or bed. Its a great space saver. Not to mention the saved space from not hauling a tent, air mattress and pump. I would consider that one of the biggest benefits over the bed tent/bed mat setup. I kept mine on my truck for 2+ years. I finally pulled it off but only because I have a 6 month old and I'm not going out 10-15 times/year right now. Leaving a rtt on all the time WILL wear on your leaf springs and screw your mpg a bit though. But I have a tepui Gran sabana (biggest model) and my sleeping bags and pillows live in there so its probably 200lbs. A smaller rtt wouldnt be as bad.
    2015whitetaco[QUOTED] likes this.
  12. Mar 23, 2016 at 9:01 AM
    2015whitetaco
    Pleasant Hill
    I have the ayer so it is lighter for sure
    I timed myself and it took me 4 minutes and 23 seconds to set up alone (just at a normal pace not rushing)
    and it took me 6 minutes 37 seconds to put away ( sat the same pace it takes slightly longer to put away because you have to zip up the case) but still nothing compared to the 10-15 minutes it took to set up my ground tent
    you don't have to deal with those bungee poles or stakes
    the RTT does have poles but they are not essential for the use of the tent its just if you want the windows open
    This thread was to look at mattresses so I'm sorry for high jacking it to a RTT pros/cons
    If you were asking me I would say hold off till you can afford an RTT
  13. Mar 23, 2016 at 4:26 PM
    Rockin&Chalkin
    Anthony
    No I don't mind the hijacking! I am trying to figure out what's going to be best. Honestly my wife and I probably only go camping maybe a half dozen times a year. So I am not sure that an RTT is going to be worth it. I have been contemplating getting a small harbor freight trailer and boxing it in and putting a rack and RTT on top. That way it can also have all my camping gear in it and I can just hook up and go.
    musicisevil and 2015whitetaco like this.
  14. Mar 23, 2016 at 4:28 PM
    Rockin&Chalkin
    Anthony
    I appreciate all the input, keep it coming.
  15. Mar 23, 2016 at 4:32 PM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Designed specifically for trucks and they make a Tacoma specific model. There are a few companies that make these:
    http://www.truck-bedz.com/
  16. Mar 23, 2016 at 4:34 PM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Bed bars for a RTT are pretty cheap. Check out Eddy at SOS concepts.
    @EddyRRT
  17. Mar 23, 2016 at 6:01 PM
    2015whitetaco
    Pleasant Hill
    Yeah the RTT was originally an impulse buy as well as the bed rack I am thinking about going the trailer route
    In the past i went camping maybe 3-5 times a year and only like 1-2 night trips
    I bought the RTT in january and Ive gone on 5 trips and I'm going on 3 in the next month
    The RTT makes it a lot easier to just get up and go making it more beneficial for the money
    I have been thinking about going the trailer route and would love to do that my only problem right now is that I have limited space so would have to pay storage fees
    I have been looking at trailers and the harbor freight looks like the best bang for my buck and I would end up boxing it up bout four feet with a water tank and propane tank built on fold out kitchen (nothing big just the essentials)
    and then rack on top with tent mounted That way I can just hook up the trailer go to the store for food then be on the road
    as of right now I'm at the point where i say "Fuck it I'm going camping" and from then it takes me about 45 minutes to get home get my bag go to the store and be on the road
    Being able to get up and go makes it easier and in turn more fun to just get out more
    My new years resolution this year was to get on one trip at least once a month
    by the end of april I will have done 8 most of witch are multiple day trips not just an over night
  18. May 22, 2016 at 11:40 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Do they not make a 5 foot version of the Air Bedz?
    Mckeiff17 likes this.
  19. May 22, 2016 at 11:51 AM
    Rockin&Chalkin
    Anthony
    Not yet, that I have seen or heard. If anyone has any new information please pass that on. What you pictured right here is exactly what I want but with the short bed.
  20. May 22, 2016 at 11:58 AM
    Sbpark
    Sbpark Well-Known Member
    2017 Subaru Outback 2.5i Limited
    One disadvantage of having a truck bed tent, RTT, etc., is if you're staying somewhere for a few days and need the vehicle to drive around, explore for your campsite you have to break down the text every time. I know these all have their own specific applications, advantages and disadvantages, etc., but I just stick with the regular old ground tent. Free's up the bed to be used for storing gear, etc. Plus it's way cheaper than buying a RTT, and better quality than a truck bed tent. With a truck bed tent you have to take all your crap out of the bed. If you're doing basic car camping just go to Costco and get a cheap big ass Coleman tent and save yourself a lot of hassle and money.
    musicisevil and nonohmic like this.
