Short bed bedding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ERDoc, Nov 16, 2011.
  1. Nov 16, 2011 at 4:38 PM
    ERDoc
    ERDoc [OP] Member
    10 Sport
    So winter is coming soon and to be honest I am too tender a flower to sleep in a tent outside all the time. So I am looking to outfit the back of my shortbed a bit. Anyone done this? Any suggestions? I mean I'll have light, tunes...heck, is there a tiny mobile heater that can plug into the bed outlet? Also, what do you put down to sleep on? Inflatable? Small pad? Raised bed? Thanks gentlemen!
  2. Nov 16, 2011 at 5:21 PM
    ShaneG
    ShaneG Well-Known Member
    Shane
    Jacksonville, FL
    11 Prerunner SR5
    In previous trucks, I've purchased a small bit of carpet and carpet padding, the same type you would purchase for your home. Laid my rubber bad mat over each, traced the outline, then cut to size. Cheap, comfortable and looks pretty good. Also easy to pull out and set to the side when you need to haul the dirty stuff as opposed to the hassle of the bed rugs I've seen designed for trucks...
  3. Nov 17, 2011 at 1:30 PM
    ERDoc
    ERDoc [OP] Member
    10 Sport
    That could work. I am hoping to take it up a notch and really make it comfy. Anyone else?
  4. Nov 17, 2011 at 1:42 PM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
  5. Nov 17, 2011 at 1:42 PM
    Sport11
    Kingsport, TN
    Dodge Ram 1500
  6. Nov 17, 2011 at 1:52 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Memory foam cut to the shape of the bed, go for the thick stuff, it'll act as insulation as well as support. Or, as mentioned above, the truck bed air mattress is nice to sleep on. For heat, try those Coleman propane lanterns. Lots of light and they will heat up that small of a space in no time, just be careful with the flame obviously. Best part is it won't drain your battery.
  7. Nov 17, 2011 at 4:35 PM
    rancher 420
    rancher 420 Well-Known Member
    Adam
    north east ohio
    2011 plain jane 4x4
    aftermarket fogs with HID LEER 100R cap pioneer head unit tinted windows silverstar reverse lights tow hitch cobra 75 c.b. vent visors new recovery hook in the front camping set up in the back ( rug, air mattress, fan, and heat)
    i sleep in the back of my truck all the time. i have a leer 100 r cap, truck bed air mattress (supper comfy) and also a propane heater that i mounted to the bed rails. the heater is a catalytic heater, and is safe for tents, however they do eat up allot of oxygen, so ca]rack a window., it throws off allot of heat so an open window will be just fine, i also have a small electric fan that i use in the summer.
  8. Nov 17, 2011 at 4:36 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    This
  9. Nov 17, 2011 at 4:38 PM
    T A C O M A
    T A C O M A Well-Known Member
    I have a cheap 15 $ inflatable bed from walmart and it works fine for me
