Short bed on an access cab???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nopinch, Mar 7, 2015.
  1. Mar 7, 2015 at 4:34 PM
    nopinch
    nopinch [OP] Active Member
    Broken Arrow , Ok
    Looking around here and there I stumbled across a video from TFLT on YT and the guy from Toyota says the the Dbl cab come standard with the 5ft box, and the access cab comes with choice of 5ft or 6 ft box. Either he was confused and said access cab when he meant double cab or, they are going to make a short box on and ext cab, which would be very cool IMO. link (skip to 2:37 mark) https://www.youtube.com/watch?v=J0HD5jLC5BE&spfreload=10
  2. Mar 7, 2015 at 4:46 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Personally I wouldn't take anything those guys say as legit, they are idiots and have been wrong with statements. I doubt there's a shortbed option for the access cab. But then again no details known yet.
  3. Mar 9, 2015 at 6:44 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    Sounds like he misspoke.
  4. Mar 9, 2015 at 6:50 AM
    Large
    Large Red
    I don't think they would put a 5' bed on the access cab, that would make too many configurations IMO. If they had some kind of PRO build with a short bed and an AC that might be plausible but ultimately you will have to wait to find out.
  5. Mar 9, 2015 at 7:14 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    would be the incross concept of years past.
  6. Mar 9, 2015 at 7:19 AM
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
  7. Mar 9, 2015 at 3:31 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The stupid thing about that.... If you go to the Toyota Website and BUILD a truck.
    The "Standard Bed" and "Long Bed" are choices but they're the same thing. Both 73.5" long.
    If you originally pick Access Cab....and scroll down to the 'Bed Length' -
    If you pick "Short Bed", it automatically changes your cab length to Double Cab.
    If you pick "Long Bed", it automatically changes your cab length to Double Cab.
    Ultimately..."Standard Cab" is the only choice you can make. I'm not sure why those other two options are even visible if you picked Access Cab early on.
  8. Mar 12, 2015 at 1:35 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    I don't see it happening due to needing a different frame. The access cab and DCSB have basically the same frame.
  9. Mar 12, 2015 at 1:44 PM
    cgs2k2
    cgs2k2 old man
    not happening. he misspoke.
