Short bed or long bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zerocool120, Apr 6, 2011.
  1. Apr 6, 2011 at 9:35 AM
    zerocool120
    zerocool120 [OP] Active Member
    Aspen, CO USA
    2011 Tacoma DCSB TRD OR
    TRD CAI
    All,
    Per my previous threads, I am looking to build an overland/expedition Tacoma soonest. I received a ton of great advice about a multitude of things...but one thing not mentioned was the short versus long bed question. I assumed that if you expect to do any off-roading, the shorter wheel base the better, but after actually looking at a 2010 Tacoma Double-Cab with short bed, I wonder what the exact different really is. The short bed seems really small. For storage and utility in overlanding, shouldn't I go with the foot longer long bed instead? Actual vehicle length increases by only 13.2 inches. I do not know the measurements in wheelbase difference, but it can't be much...then again is it? With a 3" lift on this truck, will I notice a difference off-roading between the two? What do you suggest and why?
    Thanks,
  2. Apr 6, 2011 at 9:44 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Short Bed my fellow warrior. Hooah!
  3. Apr 6, 2011 at 9:46 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The shortbed is really small , but for your stated usage , is probably the correct choice .
    Shorter wheelbase is better offroad .
  4. Apr 6, 2011 at 10:07 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    DBL Cab LB FTMFW!
  5. Apr 6, 2011 at 10:08 AM
    OZ-T
    Peter North
    British Columbia
    High five brother
  6. Apr 6, 2011 at 10:17 AM
    OZ-T
    Peter North
    British Columbia
    I have to agree
  7. Apr 6, 2011 at 10:22 AM
    Fennywald
    Fennywald Betty Blue
    Virginia Beach, VA
    SR5 Tundra 4X4
    took my dclb thru a LIGHT trail 3 months after i got it bone stock and only once really had a clearance issue. If you're gonna be planning on rougher trails, i would go with the short bed unless you don't mind doing a 6 in lift down the road. Also you can't get the off road package on the long bed. just 2 cents from a lond bed owner.
  8. Apr 6, 2011 at 10:26 AM
    OZ-T
    Peter North
    British Columbia
    The OP stated he wanted a DC .
    Therefore the correct choice is DCSB .
  9. Apr 6, 2011 at 1:07 PM
    zerocool120
    Aspen, CO USA
    TRD CAI
    All,
    Wow! Lot's of comments! The reason I need a Double-Cab is due to having two children that have to accompany me everywhere:D. I was planning an Icon stage 4 3" lift, but nothing more (suspension wise). The bed, whatever size it is, will have a custom bed rack (hopefully built by Relentless!) to take on the RTT. I will try to fit all of the other stuff (onboard air, Engel fridge, water, fuel, etc.) into that bed rack system somehow. Being a novice, I was just wondering if there is really a difference between the two bed sizes on light off-road applications. I will not be doing any rock-crawling (unless I put myself in a really bad situation, in which case I will just use exploseves to solve the problem:eek:!). Thanks for the advice.
  10. Apr 6, 2011 at 2:11 PM
    OZ-T
    Peter North
    British Columbia
    Light offroad with that lift , you will be fine with the DCLB .
    If you intend to get the TRD Offroad edition , it only comes in a shortbed though .
    You can get the longbed as an SR5 or TRD Sport .
  11. Apr 6, 2011 at 9:57 PM
    DontBSkerred
    DontBSkerred Active Member
    Surfside Beach, SC
    06 PreRunner SR5
    Just give it some time
    I've got the double cab short bed, and this thing has a great turning radius.
