Short Bed Tacoma Sleep Recommendations?
Discussion in 'Outdoors' started by db44, Oct 1, 2019.
  1. Oct 1, 2019 at 11:03 AM
    db44
    db44 [OP] Member
    derek
    I've just got my Tacoma ready for a camping trip, and looking to get some type of camp mattress for the back of the truck that isn't 72" long like most are. Would be great to get something the length & width of my short bed Tacoma as i've got storage underneath. Recommendations? Thanks a lot!
  2. Oct 1, 2019 at 9:00 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I'm feeling nice! FREE BUMP!
  3. Oct 1, 2019 at 9:02 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Would you want to just cut some foam or something?
  4. Oct 2, 2019 at 7:01 AM
    huachuca
    huachuca Well-Known Member
    Al
    Tarboro, NC
    2012 4WD DC w/TRD offroad
    There are any number of vendors out there that will make a custom mattress to your specs - just google 'custom made mattress near ????????????'
    If you were anywhere near northeastern NC, I'd recommend Southern Mattress in Rocky Mount. They've made a couple for my campers over the years and do a great job.
  5. Oct 2, 2019 at 7:09 AM
    Elkyri
    Elkyri Living on the Raggedy Edge of the 'Verse
    2017 DCSB TRD-OR
    Mattress "topper" cut to size? May not give you the amount of cushion you want but come in various thicknesses.
  6. Oct 3, 2019 at 10:35 AM
    db44
    db44 [OP] Member
    derek
    Thanks all, I thought about the egg crate foam on top of the wood platform but figured it wouldn't be all that comfortable. Most inflatable mattresses are 72" so was hoping someone knew of a shorter one specific for these short beds. Appreciate the replies though!
  7. Oct 3, 2019 at 10:39 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  8. Oct 3, 2019 at 4:08 PM
    smartbomb
    smartbomb rcvr/xmtr
    usually northwest of you
    2006 4-door prerunner long bed
    3" suspension lift, hard canopy, light bar in hood, ditch lights, aircraft cargo bars, powdercoated steel spares, desert tires, bed cargo bars (for rifle cases), misc interior doo-dads
    get a sheet of styrofoam from a big box store and cut it to size. then use an air mattress
    the styrofoam does a lot to keep you away from the cold bed. maybe use a piece of plywood under it if your bed is corrugated (most are)
  9. Oct 3, 2019 at 4:17 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Get a Full size memory foam topper and trim it to size. Also I put mine inside a double size sleeping bag and it has worked fantastically. No need for an air mattress and its comfortable enough to seep on your side. The sleeping bag adds a good 1.5-2 on top of the thickness of the memory foam.
    IEsurfer likes this.
