short or improved shifter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cicada83, Jan 18, 2009.
  1. Jan 18, 2009 at 6:07 PM
    cicada83
    cicada83 [OP] Well-Known Member
    Midland, MI
    Retro white SR5 4x4
    Volant ram air, Bestop soft topper
    Hey everyone I am looking into getting something to improve my shifting. It is a little notchey at times and catches going into 2nd aobut 50% of the time. I did change out the tranny lube with redline mt90 and that did help, but I am thinking if I improve the shifter that should resolve the problem.
    I have been looking at the urd short throw, but not really sure I want really short throws. Anyone know a good product that may slightly shorten my shift but is also designed to make shifts more smooth. I hope someone can help me out. Thanks for your time. oh yeah 2.7 2008 Tacoma 4x4 5 speed.
  2. Jan 21, 2009 at 2:28 PM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    any ideas on this, any input would be great...
  3. Jan 21, 2009 at 2:30 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    A smaller clutch??? tighten the gear ratios (but i wouldnt do that)
  4. Jan 21, 2009 at 2:40 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    URD short-throw shifter will help.
  5. Jan 21, 2009 at 5:50 PM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    I have been thinking about the URD short shift. How would that change the shift feeling? also is it harder to get into the gears? I had a short shift on a VW jetta I once had and I was not a big fan. Like I said shortening the shifts would be "okay" but I don't want much more then 20% shorter. What about changing the bushing or a lubrication?
  6. Jan 21, 2009 at 5:53 PM
    Lentsnh
    the URD makes the gears shorter together and less having to use muscle to get it into gear. I belive that URD Short throw kit has everything you need to make it right.
    but you can go to getting a smaller clutch or bushings
  7. Jan 21, 2009 at 6:25 PM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    when you say smaller clutch or bushings I am not sure what you mean. My truck only has 4000 miles on it so i don't want to pull the clutch just looking to make 2nd gear catch less when shifting from first, a little smother shifts...will a smaller bushing do this or the urd short throw?
    Thanks for the replys guys.
  8. Jan 21, 2009 at 6:30 PM
    Lentsnh
    No problem. smoother shifts.... go with the URD. a smaller clutch and new bushings could be costly. sorry its been a loong day
  9. Jan 22, 2009 at 7:30 AM
    mjp2
    NJ
    Yeah, you'll hate trying to get into reverse with the URD kit, at least until you get used to it. After that you'll wonder why you ever had trouble with it.
  10. Jan 22, 2009 at 7:33 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    X2 on the URD, I had one on my old truck and it was a great product.
