Short Throw for TRD 6 Speed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SportyTuRD, Nov 17, 2009.
  1. Nov 17, 2009 at 6:51 AM
    SportyTuRD
    SportyTuRD [OP] Well-Known Member
    Is there such a thing? This is my 1st manual transmission truck...have had all kinda of Manual cars (mostly mustangs...) but was curious if such an animal exists and what quality are they?
  2. Nov 17, 2009 at 6:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    URD makes one, and one other company I cant remember off the top of my head right now.....
  3. Nov 17, 2009 at 6:55 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Yes, there are several of them.
    TRD
    URD
    B&M
    I don't have any experience with any of them and they each have their pros and cons.
    Your best bet would be to research all three and make an educated decision.
    Marc M
  4. Nov 17, 2009 at 7:08 AM
    SportyTuRD
    Thanks I did do a search but it seem like everythgin comign up was abolut modifying etc...
    My 08 stang I put a short throw sifter (roush) and i loved the notchy feel and the throw was reduced from 7 inches to 3.5
    I dont need the arm to be shorter just want the throw improved.
  5. Nov 17, 2009 at 7:12 AM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    URD is the choice of many, I have it and it is great. However the halves that are on it seem to fail on some people's. I have had mine on for over 2.5 yrs. no problem yet. The TRD and B & M are solid pieces and are noisier, but you never have to worry about failure. Good luck!
  6. Nov 17, 2009 at 7:14 AM
    Marc M
    Marc
    '06 TRD O/R Dbl-Cab
    The TRD shifter is replaced with a shorter shifter and has an adapter plate at the bottom for throw shortening.
    The URD uses the existing shifter and adds an adapter plate and adds a piece on the end of the existing shifter to shorten the throw.
    I know nothing about the B&M. A friend of mine has one but I've never looked at it.
    Marc M
  7. Nov 17, 2009 at 7:14 AM
    SportyTuRD
    Are the TRD and B&M as easy to install? are the Throws all the same?
  8. Nov 17, 2009 at 7:18 AM
    Marc M
    Marc
    '06 TRD O/R Dbl-Cab
    They are probably all very similiar since you have to pull everything from the top of the tranny housing. I don't believe you have to go under the truck for anything.
    I am personally looking for the TRD one myself.
    Marc M
  9. Nov 17, 2009 at 7:53 AM
    jassco
    jassco Well-Known Member
    Boston
    2008 4runner, UrbanRunner Silver
    I'm about to install the URD on mine. URD re-uses stock shifter which is 2 pieces telescoped between insulating rubber compound(reduces vibs and noise) and is just a machined adaptor. The TRD is also a good unit and replaces entire shifter but costs 2x the URD adaptor.
    B&M is solid piece so works great but no rubber insulator, not an issue if you like it noisy and prob vibs like hell. My friend has one on his 1st gen. When he starts it up if your is near it hits you pretty hard and vibs like crazy. I also cannot find the B&M anywhere or on thier site. They dont even list Toyota anymore......
  10. Nov 17, 2009 at 7:53 AM
    SportyTuRD
    According to the URD site their's is easiest to install...But the "other brands" are mor noisey because they use solid shifter arms and URD uses the stock...I just don't care for the "loose, squishy" feeling of the stock truck Shifters.
  11. Nov 17, 2009 at 8:04 AM
    jassco
    Boston
    Yes this is a preference thing, either you like the rock solid feel with more vibs or less vibs and little less solid. Good luck finding second gen B&M, I could not seem to find it.
  12. Nov 17, 2009 at 8:11 AM
    dktaco
    Josh
    Yes, URD is easy to install...and they still haven't addressed the failure when the halves separate. I have contacted them numerous times and NO response. Go figure!
  13. Nov 17, 2009 at 8:13 AM
    SportyTuRD
    where is the best place to buy The TRD?? It cost more but i want to be abel to compare prices.
  14. Nov 17, 2009 at 8:21 AM
    2006TRD6SPEED
    2006TRD6SPEED Member
    Brett
    Detroit
    06 TRD offroad 6speed my fourth toyota truck
    there always dealers in the carolinas and in california that have had great deals on TRD parts in the past. I priced one frome the dealer last year $220-ish. My buddy had one It was great. I think it was like 35% shorter throw, quite simple install too.
  15. Nov 17, 2009 at 8:23 AM
    jassco
    Boston
  16. Nov 17, 2009 at 10:06 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  17. Nov 17, 2009 at 11:04 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    The TRD shifter is the best in my book. It has a much more solid feel compared to the URD when you shift. I've drivin a truck that had the URD then switched to the TRD and the difference is noticeable.
