short throw shifter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 70 gto, Feb 24, 2017.
  1. Feb 24, 2017 at 2:29 PM
    70 gto
    70 gto [OP] Member
    2020 tacoma trd off road v6 6 speed manual
    stock for now
    question
    can the shifter be changed with the transmission still in the truck? manual transmisson
  2. Feb 24, 2017 at 2:36 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    ChemDawg likes this.
  3. Feb 24, 2017 at 2:45 PM
    70 gto
    70 gto [OP] Member
    stock for now
    thanks, that looks like it will work. wasn't sure if there would be clearance, but, looks like easy install
  4. Feb 24, 2017 at 4:09 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    TDR shifter install - Easy, peasy. The center console comes out. The shifter hub is spring loaded - push down in the center part and 1/4 turn CCW. It lifts out. Then remove 4 bolts on the housing and install the spacer. Reinstall the housing with the longer bolts. Insert new shifter and pop the hub back into place. Reinstall the center console. Took me less than 1/2 hour on mine.
