Short Tube Installation Shops - Hou, TX
Discussion in 'Performance and Tuning' started by Lurkin, Aug 17, 2012.
  1. Aug 17, 2012 at 10:13 AM
    Lurkin
    Lurkin [OP] Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I realize that there is a TX folder and a Houston thread, but I've seen quite a few of the local performance types posting here, so I thought I would start here.
    I am considering getting the DTSTs and I am looking for recommendations on where to get them installed in the Houston area. I know the "reliable exhaust shop" line and can also search them out, but I want to get some advice from those that have actually done a ST install or know someone who has, since I would more then likely have a shop remove the stockers, do the welding and install the headers.
    I am on the south side of Houston but would be willing to drive a bit if necessary. I am a bit leary of even trying the DTSTs as I don't like mods that I can't totally back out of (without serious backout cost anyway), but I also want to try the next round of NA mods. I've also been considering the URD CAI and MAF Cali, but I am still very concerned about that CAI with my Grillcraft.
  2. Aug 17, 2012 at 10:17 AM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    Not sure where torspd is in the houston area but he gets almost all his work done at powerfab. They did a set of shorties for his girl I believe. Shoot him a pm.
  3. Aug 17, 2012 at 11:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Thank you Outlaw. You are correct sir.
    You have a few options as far as how you want to install the headers. Just depends on if you want to spend extra or not. Let me find a link.
    Here you go. This is what I had done to my girl's truck.
    http://www.xr-underground.com/forum/showthread.php?t=38141
    That is just one option. Once you check it out, then ask whatever next questions you have, and I will be happy to help.
