Shorted reverse lights...
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1996tacoma4x4, Sep 20, 2019.
  1. Sep 20, 2019 at 6:12 PM
    1996tacoma4x4
    1996tacoma4x4 [OP] Member
    Daniel
    1996 Red Tacoma
    3.5 lift in rear
    :annoyed:I’ve got a 96 Taco and trying to find the short that’s causing my reverse lights and dash board gauges not work. Are there any common places that they short out? Already replaced fuse, and it all works, till I put it in reverse, then it pops and all goes out. It’s a manual
  2. Sep 20, 2019 at 7:00 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Usually a trailer connector is a good place to check, although if you just have a 4 pin one, thats probably not it.
  3. Sep 20, 2019 at 7:52 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I had the exact same problem back in 2015. It's caused by a faulty reverse light switch on the transmission. It kept popping the fuse to the gauge cluster and A/C. Dealership charged me $38 for the part and $300 for labor/troubleshooting. Save some money and just fix it yourself.
    Part Number: 84210-52050
  4. Sep 21, 2019 at 1:51 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As was said the switch can short out with age.
    Also look for rubbed wires coming from the switch harness.
    There can also be a short in the area of the tail lights or in the light harness .
    Are we talking Manual or Automatic??
    Makes a difference in the switch
