Shorter rear bump stop for 2nd gen
Discussion in 'Street Trucks' started by gstodd, Feb 2, 2024.
  1. Feb 2, 2024 at 10:19 AM
    gstodd
    gstodd [OP] Well-Known Member
    2005 2wd base 5-lug
    Did some searching but didn't come up with any definite answers so figured I would ask.
    Has any one installed a set of shorter stock style rear bump stops on their 2nd gen?
    I've found that after swapping in a set of 4wd rear leaf springs that I'm bouncing off the rear stops on larger dips and bumps. Yes, I know I could slow down but I drive aggressively and that's not changing after almost 40 years.
  2. Feb 2, 2024 at 10:25 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    If you went with a shorter bump are your shocks long enough to handle the extra travel without bottoming or topping out? Shortest bumps I've seen for the rear in the oem location is 1.9"
  3. Feb 2, 2024 at 10:25 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    you have anymore details on this? because my oem 4wd bump stops are like 2inchs tall. and ive bottomed out but my leaf spring are absolutely shot! any pictures?
    heck I'm installing the Timbren rear bumps tops on my OME Springs this weekend which are way longer but figure if im pulling something i want all the spare stop i can
  4. Feb 2, 2024 at 10:46 AM
    gstodd
    2005 2wd base 5-lug
    I guess I should have clarified. This is on a base 5-lug and the 4wd springs were used for lowering it. The shocks are stock with only 50K on them so they are still good and should be able to handle the extra inch of travel as I'm only 1 - 1 1/2" from the bump stop currently.
