shorty header for low rpm hp gains
Discussion in '4 Cylinder' started by monkey wrench, Jan 21, 2012.
  1. Jan 21, 2012 at 6:17 PM
    monkey wrench
    monkey wrench [OP] Well-Known Member
    sean
    somerset, ca
    stock 4x4
    new stereo, rear leaf tsb, front 5100s @ .75. weather tecs and wet okoles.
    i'm concidering a shorty header to help with hp below 3,000. does such a thing exist?
  2. Jan 21, 2012 at 6:18 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    nope. only header options are LCE and DT. go ahead and go into the 4 cylinder subforum, search forum and type in header.
  3. Jan 21, 2012 at 7:19 PM
    monkey wrench
    sean
    somerset, ca
    stock 4x4
    thanks. So most headers are designed for 4000+ rpms?
    I searched around and was not able to locate the info I was looking for.
  4. Jan 21, 2012 at 10:52 PM
    Thorpedo26
    Thorpedo26 Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    There are threads on this very page that will help. There's the DT and LCE? I hear the lce has slightly better numbers down low but both have decent gains over stock.
  5. Jan 22, 2012 at 9:34 AM
    monkey wrench
    sean
    somerset, ca
    stock 4x4
    I saw that thread. I did not see any actual hp or torque numbers. I saw one reference to 3500+ rpms. im looking for concrete numbers. I'll look look around some more.
  6. Jan 22, 2012 at 11:00 PM
    muleyhunter
    muleyhunter Git-r-Done
    Trevor
    Logan Utah
    07 2.7L 4x4
    Afe Pro dry cold air intake, lce header, dynamax super turbo muffler, scangauge II booming stereo
    Both the dt and the lce will serve you well. The lce will give you slightly better torque and hp readings than the dt on a dyno test but they are so close that you won't be able to physically tell a difference between the two. I have had both the headers on my truck and that's what I came up with. I'm still waiting on my friend in the mechanic shop that ran the dyno test for me to get me my results graphed but as soon as he does look for it on the lce vs dt header thread.either one will serve you well. the price is about a 40 dollar difference
  7. Jan 23, 2012 at 9:34 AM
    monkey wrench
    sean
    somerset, ca
    stock 4x4
    cool. i'll look for the results.
  8. Jan 23, 2012 at 11:32 AM
    rjg
    rjg Yes
    RJ
    PA
    2007 Regular Cab 4x4 5 Spd 2.7
    LCE header, AFE filter, Blinglight Fogs, URD Short Shifter, Delay wipers
    I'm on the fence whether to buy the LCE for my 2.7. It would be nice to have a little extra torque for the hilly roads locally and to see an increase in MPG (currently 21 with winter gas).
    At $430.00, it would take me about 1.5 years to recover the cost IF it increased my MPG by 2. I can't make up my mind!
  9. Jan 23, 2012 at 1:15 PM
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Go for it its the best mod you can do for the price. With a header your opening up the exhaust flow making it easier for your engine to push exhaust out of the piston chamber. When you relieve that pressure it makes it easier for your engine to run. Less work on the engine = less wear over time. Not only will you get better hp and torque but in the long run it will be better for your engine. That its if your not hot rodding your engine
  10. Jan 23, 2012 at 1:16 PM
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Plus it will more than pay for itself with time
  11. Jan 23, 2012 at 4:24 PM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
