Shotgun advice..??
Discussion in 'Guns & Hunting' started by sandman427, Sep 8, 2009.
  1. Sep 8, 2009 at 9:58 AM
    sandman427
    sandman427 [OP] KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    Whats up fellas Im in the process of buying a shotgun and handgun as well and needed some advice... I am a first time buyer so all and any info would help... I saw at Big 5 yesterday a 12 gage shotgun with a pistol grip and adjustable stock by Mausberg 500A for 379$... What yall think...?? And Im looking in between 2 handguns... The Sig Sauer and the Gloc-40....
    Thank Fellas
    Amir
  2. Sep 8, 2009 at 10:22 AM
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
    What is the shotgun going to be used for? What is your handgun going to be used for? Lots of different firearms for different applications. If you plan on getting a .40 cal, I would buy a 9mm barrel from Lone Wolf to cut the price of ammunition in half for practice.
  3. Sep 8, 2009 at 10:26 AM
    sandman427
    Amir
    BAMF TACO!!
    the shotgun i guess more for home protection and just letting off some rounds in the desert... The handgun is the same thing... i may be a newb but who or what is Lone wolf..?? The reason y i was looking at the Gloc 40 was cuz a buddy of mine just purchased one and i liked it... But u have a point i do want to take the price of rounds into account..
  4. Sep 8, 2009 at 10:31 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    What are they going to be used for?
    If you are looking for a "Throw in the back of your truck" shotgun that will never let you down, then the Remington 870 is about as tried and true as you can get.
    If you are going to be shooting sporting clays, trap, skeet shooting, hunting, then the answer may very.
    As for handguns, Sigs and Glocks are both great guns.
    I'm sure you will get a lot of "Glocks suck. I have a Sig." or "Sigs suck I have a Glock." but they are both good guns. Just get one that has the features you like and feels good in your hands.
    Might I also recommend the Walther P99 (feels like part of my hand)
    Good luck.
  5. Sep 8, 2009 at 11:01 AM
    sandman427
    Amir
    BAMF TACO!!
    Thanks Ill check out that p99.... I had talked to someone the other day and he was telling me that the SIGs take more maintenance then the Glocs... Is that true...?? Oh what do u think of the Mausberg..??
    Thanks again for the info... Amir
  6. Sep 8, 2009 at 11:24 AM
    Arcanite09
    Arcanite09 Well-Known Member
    Nico
    Sacramento, CA
    09 4x4 TRD
    Alpine 9887, CDT HD-62Z fronts powered by Phoenix Gold ZX450 and Polk MMC650 rearpowered by MTX 2150x. Premier TS-SW1201S4 sub powered by SOUNDSTREAM Class A 10.0
    I love my Mossberg 590a1. Its built like a tank! 20" heavy barrel, 8+1, mossberg ghost rings, came with a bayonet. Id recomend a mossberg although there was an issue with a shippment of em @ Big5 over here like 8 months ago, my cousin purchased a standard 590 and the tube spring was defective along with like 5 others from that store.
  7. Sep 8, 2009 at 11:29 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    You can't go wrong with a mossberg! As far as the pistols, pick the one that feels better to you. You can always mod the hell out it later down the road. (change the sights, pistol grip, barrels, etc...)
  8. Sep 8, 2009 at 11:30 AM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    More main't than glocks? These aren't cars were talking about. All handguns should all be at least field stripped and cleaned from time to time. From sheer use, parts don't generally wear out that often. Striker fired guns have less parts than conventional SA/DA guns but there really isn't much of a maintenance difference.
    Mossbergs are good shotguns. But honestly I'd stay away from those "tactical" ones sold at Big 5. The parts are from ATI which is renowned for cheap bad fitting parts.
    If you want to customize your shotgun later on, 870's have a wider after market selection to choose from. Shoulder several different brands and get a feel for which controls are better for you and which point more naturally.
  9. Sep 8, 2009 at 11:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sigs vs. Glocks for maintinance....Hmmm....My Sig and Glocks get about the same. They strip easilly, and are a peice of cake to clean. Most times I just run a snake thru the barrel, and put a few drops of oil on the slide rails, and call it good.
  10. Sep 8, 2009 at 11:35 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Basic, starter gun: I'd second the recommendation on a Remington 870. Standard 12 gauge pump action, won't let you down, and they're also about $300.
    Personally I feel like mossberg 500's are a bit more cheaply made; I think there's a reason most shotgun owners have at least one old 870, and every gunstore has a wide selection of used 500's. :) But i'm probably biased.
  11. Sep 8, 2009 at 11:38 AM
    DellGSG5
    DellGSG5 Well-Known Member
    Dell
    San Diego, California
    2009 PreRunner TRD
    Step rail, Grill guard, bug deflector,bed lights, Window Deflectors.
    I have my mossberg 500 for over 10years and I never had a problem. On pistol Sig 226 is my pick.
  12. Sep 8, 2009 at 11:41 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    no to dis all the main guns and all but i use a charles daly 12 ga that i got at walmart.[​IMG]
    i have also used high end beneli shotguns and by far the walmart shotgun outruns them in my opinion.
  13. Sep 8, 2009 at 11:47 AM
    sandman427
    Amir
    BAMF TACO!!
    Right on fellas i appreciate the help... The only reason y Im shooting for the mossberg is just cuz big 5 had a sale on them... 479$ to 379$... IS this just a normal sale..?? Or are these guns not selling cuz thats a pretty big mark down 100$...
  14. Sep 8, 2009 at 11:54 AM
    EMR
    So Cal.
    2012 Tx Pro
    If it's for a 500a then no it's not worth it IMO. For a regular 590, thats questionable if its a deal. For a 590a1 yes it a decent deal for Southern CA. Big 5 puts everything on sale rotation anyway. If you miss this sale, then wait a month and try again.
    Though I'd still pass on their pistol grip. I'm not a bells and whistles hater, I just think ATI should be owned by Matel.
    *edit: if this is going to be your first shotgun, I might recommend that you get Big 5's Mossberg 500 Combo. It comes with a 18.5"barrel and a 26" barrel for shooting trap etc. It's cheap and it'll give you the most versatility. It goes on sale there all the time. I might pass on that 590 until you know more of what feels comfortable for you.
  15. Sep 8, 2009 at 12:27 PM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    Remington 870! If you ever get tired of it, the resale price will be better than the Mossberg.
  16. Sep 8, 2009 at 1:36 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Turners has a Remington 870 for 330 I think. Really doesn't matter with Mossberg, Remington, or Winchester. Everyone has a side they pick, I wanted a Remington 870 and ended up with a winchester 1300 defender for 250, and I've been happy with it ever since, no regrets there. Also where in socal are you at?
  17. Sep 8, 2009 at 1:48 PM
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    I agree that the Rem. 870 is a better long-term value than a Mossberg. I'm also pretty partial to the Binelli Super Nova, costs a little more $ than the Remington but not all that much and a really great pump shotgun.
    Sig or Glock? I prefer the Sigs generally, but you can't argue with success and the Glocks have been extremely popular, and generally cost less too. I'd tilt toward a 9x19 rather than a 40 if you're mostly just going to be blowing holes in the desert. Ammo way cheaper, less recoil, and still a fairly credible personal defense round.
  18. Sep 8, 2009 at 1:53 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Remington 870, my bro has had one for atleast a decade now and has taken it threw tons of muddy rainy situations and it still goes hard.... oh yea he blasted 25 doves opening day
  19. Sep 8, 2009 at 1:55 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    well handgun wise. go for the sig saur. the coast guard uses the DAK version which is just a more refined version of the P228 i believe. its more apt for concealed carry and it packs a .40 cal punch. other models go from 9 MM up to 45 cal. but you pick the best round for what your scenario is going to be for. as for the shotgun, personally, mossbergs are great guns. people will tell you otherwise. adn tell you that because of the aluminium reciever, they will screw up and warp and all this other stuff. but the AR15 has an aluminum reciever and it does jsut fine. also the mossberg 590s are Mil spec approved.
    the remington on the other hand is also a good gun. its been around since the beginning of popular shotguns. both guns cycle differently. mossbergs are a litle more solid feel to it. rems, are more smoother in certain areas. but its just like a chevy vs ford debate. in the end id say, screw it and go for both when you have the money.
  20. Sep 8, 2009 at 2:00 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I've got a Remington 870 Express Magnum Home Defender w/ a pistol grip and a .40 Glock 23c...IMO this is the ideal setup lol
