Shotgun troubleshooting
Discussion in 'Guns & Hunting' started by Southerner, Dec 29, 2015.
  1. Dec 29, 2015 at 7:52 PM
    Southerner
    Southerner [OP] Well-Known Member
    S
    The great state of TN
    2015 Grey Tacoma Access cab
    So I just acquired an old JC himmel 12,gauge model 20. The only problem is the pump won't move backwards but half an inch. Ive taken most of it apart to try and figure out what's going on. The firing pin container (no idea what the name is) seems to be getting stuck on something. Any ideas?
  2. Dec 29, 2015 at 7:52 PM
    Southerner
    S
    My bad. J c higgens.
  3. Dec 29, 2015 at 8:00 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    if you cant figure whats going on then take it to a gunsmith. I wont fuck around with it if I were you-
    Don't take any chances brother. nice shotgun btw congrats!
  4. Dec 29, 2015 at 8:15 PM
    Southerner
    S
    The guy that gave it to me did that and was told repairs would be more than then gun is worth. I'd like to fix it if I can.
  5. Dec 30, 2015 at 7:37 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    are there pins to pull the action apart?
  6. Dec 31, 2015 at 7:03 AM
    doghair
    doghair Well-Known Member
    Phoenix
    2013 Single Cab 4x4
    Those are cool old guns but not worth a lot of magic beans. I can see a gunsmith per/hour rate going past it quick. I found this through the manual sticky, don't know if it will help but it couldn't hurt.
    Good luck, I hope you can figure it out.
    http://stevespages.com/pdf/jchiggins_20.pdf
  7. Dec 31, 2015 at 4:23 PM
    Southerner
    S
    Thanks. I've been looking through that. When I get it figured out I'll post what I figure out.
  8. Dec 31, 2015 at 9:15 PM
    Southerner
    S
    Ive pulled it apart as far as I can. I suspect that there's a broken piece somewhere inaccessible that prevents it.from going back.
  9. Jan 6, 2016 at 7:36 PM
    Southerner
    S
    I just fixed it! Mostly... I discovered after forcing everything and banging up a fifty year old shotgun that probably sat in a truck box that the pin that holds the firing pin in place broke and wedged against the side. Now I need a replacement and I've got another working shotgun!
    doghair likes this.
