Should a dealership replace rear cam plugs when replacing valve cover gasket
Discussion in 'New Members' started by Bernie0008, Jan 14, 2020.
  1. Jan 14, 2020 at 8:55 AM
    Bernie0008
    Bernie0008 [OP] Member
    1997 T100 SR5 4x4
    I had the valve cover gaskets replaced on 3.4l 5VZFE six months ago at the dealership and now oil is leaking again and now the dealership says that it is the rear cam plugs. Should they have been checked and replaced if necessary when the valve cover gaskets were done? Thanks.
    irayfz6 and Black DOG Lila like this.
  2. Jan 14, 2020 at 9:04 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm not 100% sure what the actual service manual says about the actual recommended proceedure for replacing the cam plugs when doing the valve cover gaskets.
    I can tell you that it would be completely retarded to go through all the work to get to the valve cover gaskets without at the very least checking cleaning and re-sealing the cam plugs.
    If it were me, I'd fight them to replace the cam plugs because I'm pretty sure it should have been done.
  3. Jan 14, 2020 at 9:11 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard. I agree with Matt - uphillshunter.
    irayfz6 and buckhuntin-tacoma like this.
  4. Jan 14, 2020 at 9:44 AM
    Merlin88
    Merlin88 $8.95 large hawaiian
    Southern Oregon
    2017 Silver SR5 V6 4x4 DCSB AT
    SSO Slimline Hybrid Bumper Smittybilt X2O 10k Wireless Winch N-Fab Rock Rails w/Removable Steps Fab Fours Premium Rear Bumper RCI Engine Steel Skid RCI Transfer Case Steel Skid RCI Transmission Steel Skid RCI Crossmember Steel Skid RCI Fuel Tank Steel Skid Pop & Lock Auto Tailgate Lock Decked Short Bed Storage System ARB OME BP-51 2” Lift Kit with ARB OME BP-51 w/adj res coil overs ARB OME BP-51 w/adj res rear shock ARB OME Differential Drop Kit SPC UCA’s w/adj Ball Joints OME Dakar Heavy Duty Leaf Packs BFG AT KO2 T/A 285/70/17 tires Ultra’s Maverick 235 17x8 wheels Full Size Matched Spare Thule TracOne Ladder Rack Toyota Matte Black Grille Smoked Amber Raptor Grille Lights Matte Black Emblems Toyota Chrome Exhaust Tip-blackout Bed Rug Tailgate Mat Optima Red Top 35 Weather Tech Side Vent Shades Weather Tech Laser Fit Floor Mats CoverKing Neosupreme Seat Covers Sabellco Tailgate Lock RedLine Quick Hood Lift Elite Subaru Tweeter’s JDMCAR liners Cupeez Scratch Protectors
    Welcome!
  5. Jan 14, 2020 at 9:54 AM
    Bernie0008
    1997 T100 SR5 4x4
    Hello everyone! Thanks for all the quick replies. That is what I was thinking uphillshunter that they should have checked them out. I just about believe that the leak out of the cam plugs might have began right after the valve cover gasket replacement.
    irayfz6 likes this.
  6. Jan 14, 2020 at 10:00 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Over 50% of the time, when people think their valve covers are leaking... it's actually the cam plugs. The cam plugs may have been what was leaking on your truck in the first place.
    Also, the more I think about it... I'm also getting closer to 100% sure replacing the cam plugs (or at the very least re-sealing them) would be in the Toyota recommended procedure for replacing the valve cover gaskets. When you pull the valve covers off, it is a near 100% certainty you will disturb/dislodge the cam plugs... and you will with out doubt, break the seal on the upper portion of the cam plugs.
    There is no way to properly replace the valve covers without addressing the cam plugs.
  7. Jan 14, 2020 at 10:18 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    irayfz6 likes this.
  8. Jan 14, 2020 at 10:53 AM
    Bernie0008
    1997 T100 SR5 4x4
    Thanks for all the advice. I appreciate it. I will feel better arguing with them about it now.
    irayfz6 and El Taco Diablo like this.
  9. Jan 14, 2020 at 1:25 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    irayfz6 likes this.
  10. Jan 14, 2020 at 3:04 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  11. Jan 14, 2020 at 3:41 PM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    Welcome, welcome. Rest assured, anything rubber revealed by removing the valve cover should be inspected and seated properly. That's maintenance 101. I just checked the manual and for Cylinder Head Assembly tasks (which you have to enter for the gasket replacements, it says (for the camshaft housing plugs),
    "(a) Remove any old packing (FIPG) material.
    (b) Apply seal packing to the bearing cap as shown.
    Seal packing:
    Part No. 08826-00080 or equivalent
    (c) Place a new housing plug in position on the cylinder
    head, facing the cup side inward.
    (d) Install the camshaft bearing cap with the 2 bolts. •
    Torque: 16 N,m (160 kgf-cm, 12 ft•lbf)
    (e) Install the cylinder head rear plate, ground strap with
    the bolt and nut.
    Torque: 8 N,m (80 kgf-cm, 71 in.-lbf)"
    Any time I disturb a formed in place gasket, I remove and replace that material.
    Hope this helps.
  12. Jan 15, 2020 at 7:56 AM
    Bernie0008
    1997 T100 SR5 4x4
    Thanks again for all the responses. Idk if I will be able to get out of paying for it but at least I know I was right about it. Thanks to all of you for your information.
  13. Jan 21, 2020 at 8:21 AM
    Bernie0008
    1997 T100 SR5 4x4
    I just wanted to let everyone who responded and helped with information that I am actually going to get half of the cost of the rear cam plugs refunded. Thanks to all your information!
  14. Jan 21, 2020 at 9:50 AM
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Awesome news!
