Should have bought a half ton
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wire4Money, Oct 18, 2020.
  1. Oct 23, 2020 at 8:49 PM
    #241
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    My son uses one on his Tacoma hauling a fully loaded truck and a 20ft camping trailer says he never has any issues and he hauls over the Appalachian mts.
    CygnusX191 likes this.
  2. Oct 23, 2020 at 9:13 PM
    #242
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    So this is a much better and clearer explanation than what I had read elsewhere. Nicely done :101010:
    Junkhead and RustyGreen[QUOTED] like this.
  3. Oct 24, 2020 at 5:59 AM
    #243
    Pg350
    Pg350 Well-Known Member
    2018 4x4 SR5 Tacoma auto
    Trd pro grill
    Exhaust valve failure requiring new head is what the dealer told me. They have had my truck for 6 days now and today said they were still waiting on parts.
  4. Oct 24, 2020 at 6:06 AM
    #244
    lpranger467
    lpranger467 Well-Known Member
    Lawrence
    2020 Tacoma TRD
    None yet
    So after reading many threads, seems like wind resistance may be bigger issue than weight. If I got a pop up around 2000lbs would I need ect on, and drive in S ? And can you stay in overdrive and still use ECT ? (Automatic trans)
  5. Oct 24, 2020 at 6:20 AM
    #245
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Idk, i've got a 5x10 aluma utility trailer i make short trips with every now, and then plus i plan to use it for much long trips for my snowmobile now. I don't find it a problem at all with the tacoma i have. When hauling my 2k lb boat, you know its there.
  6. Oct 24, 2020 at 6:41 AM
    #246
    lpranger467
    Lawrence
    2020 Tacoma TRD
    None yet
    Didn't realize there was more than 1 S gear, thanks
  7. Oct 24, 2020 at 6:57 AM
    #247
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    S just refers to "shift mode" (transmission in D, then move it over to the left)
    The number refers to what gear you want to limit the shifting to. For example, S4 means the truck will use gears 1-4, which is recommended for towing (4 being the 1:1 drive gear, 5 and 6 being your overdrive gears)
    Note: S mode defaults to S4 when you "shift" over to engage it. Keeps trailer work simple
    Junkhead, synaps3, Chew and 2 others like this.
  8. Oct 24, 2020 at 8:30 AM
    #248
    lpranger467
    Lawrence
    2020 Tacoma TRD
    None yet
    Ok thanks, with a lighter weight pop up would i be able to do S 5 for higher gas mileage ?
    QUOTE="CygnusX191, post: 24422078, member: 203575"]S just refers to "shift mode" (transmission in D, then move it over to the left)
    Note: S mode defaults to S4 when you "shift" over to engage it. Keeps trailer work simple[/QUOTE]
  9. Oct 24, 2020 at 9:01 AM
    #249
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    [/QUOTE]
    You can but if you get any kind of incline or large crosswinds I would leave it in S4. Good thing is while in S mode you can just click the shifter forward/back to set the gear limiter.
  10. Oct 24, 2020 at 9:03 AM
    #250
    Toyko Joe
    Toyko Joe Here for the pictures
    Ouch.
    Are you getting the 3.5l or 2.7l ecoboost?
    :anonymous:I have the 2.7l and let me tell you... head and shoulders above the Tacoma with regards to power feel, comfort and overall fuel economy.
    However I miss some features of my Tacoma can’t think of any right now other than seat width, and maybe the fact that this forum is so much better than the Ford ones.
    Junkhead likes this.
  11. Oct 24, 2020 at 9:04 AM
    #251
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I tow a Coleman west lake pop up in S4. I see no real reason to go to fifth gear - unless you want to speed above 65 mph. 235/85 16 tires.
    Chew and CygnusX191 like this.
  12. Oct 24, 2020 at 9:16 AM
    #252
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Imagine comparing completely different classes of trucks, and then bitching about it lmao
    Junkhead, kimo, Boghog1 and 2 others like this.
  13. Oct 24, 2020 at 9:24 AM
    #253
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I'd buy the twin turbo before I'd buy a Ford.
    Junkhead and CygnusX191 like this.
  14. Oct 24, 2020 at 9:32 AM
    #254
    Pg350
    Trd pro grill
    Getting 2.7 for MPG and power. Cant be any less reliable than my current tacoma so I figured might as well get more room, power. I still love tacomas also.
    Toyko Joe[QUOTED] likes this.
  15. Oct 24, 2020 at 9:33 AM
    #255
    canyonchaser
    canyonchaser Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    For the visual folks among us...
  16. Oct 24, 2020 at 11:06 AM
    #256
    Toyko Joe
    I think you’ll be pleasantly surprised. I have not had a single issue with mine I have 50,000 miles after two years. Very quiet cabin and I get 24+ mpg. I have the 3.55 rear end with the electronic locker.
    To those anti-Ford folks. Just because it’s different doesn’t mean it’s bad. I’ve owned every brand of truck other than Nissan and everyone one of them has had some quirks. What works for me now is my Ford. My Tacoma suited me well when I had it. :amen:
    RatAssassin and CygnusX191 like this.
  17. Oct 24, 2020 at 4:02 PM
    #257
    lpranger467
    Lawrence
    2020 Tacoma TRD
    None yet
    I just figured less rev in S5 ?
  18. Oct 24, 2020 at 4:04 PM
    #258
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Your gearing is "higher" so to make power, it'll downshift more often. You'd only get "less rev" if you're driving downhill or on flat ground and aren't above 70 mph (give or take)
    Chew likes this.
  19. Oct 25, 2020 at 6:43 AM
    #259
    Pg350
    Trd pro grill
    Our local Sheriffs department has many 4x4 2.7 F150s. Many with almost 100000 miles of hard abuse and none have had as many issues as my Tacoma in 32000 miles
  20. Oct 25, 2020 at 6:58 AM
    #260
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Do you work for motor pool for your local sheriff's department? As a DOT guy I see a lot of police vehicles worked on, I'm going to tell you right now they absolutely have issues.
    Boghog1, 0xDEADBEEF and Chew like this.
