Should have bought a half ton
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wire4Money, Oct 18, 2020.
  1. Oct 19, 2020 at 7:52 AM
    #81
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    I recommend purchasing a ~$3000 3/4-ton of early 2000 origin and making it your designated tow truck. And since this is a bitchin' and moanin' thread about towing quality, make sure that you get a long bed, not a short bed: they tow better. Mine's only a 1/2ton, a '97 long bed with a Leer fiberglass bed cover. I leave my camping gear in it full time, always ready to go to the lake. And if I have to actually CARRY SOMETHING OF ANY SIZE IN THE BED, like plywood, I don't have another reason to regret owning a Taco. It carries and tows everything I require as good as can be expected, without drama.
    Every man in a lifetime will find that he needs a $2000-$3000 full-size truck many times along the way. Go ahead and gitcha' one now and stop your bitchin'.
    DJB1 and CygnusX191 like this.
  2. Oct 19, 2020 at 7:54 AM
    #82
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I'd disagree. It doesn't sound right as I pull 3 different trailers at times that weigh more than this one. Check the bearings, wheels (and brakes if you have them) on that trailer. If you're constantly climbing thousands of ft inclines then I can understand the complaining.
    CygnusX191 and synaps3 like this.
  3. Oct 19, 2020 at 7:54 AM
    #83
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    4th is the perfect gear. Automatics are only doing 1700rpms at 65mph in top gear. There is very little power at that rpm towing a trailer. There is nothing wrong with truck.
  4. Oct 19, 2020 at 7:55 AM
    #84
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Shoulda, woulda, coulda got a MT :D.
    I have towed my 8' x 14' landscape trailer w/o any issues with a exmark or a 2305 JD many time with any issues. Now, back up a small grade towing any weight is no fun.
    EDIT - "Your vehicle is designed primarily as a passenger-and-load-carrying vehicle. Towing a trailer can have an adverse impact on handling, performance, braking, durability, and fuel consumption. For your safety and the safety of others, you must not overload your vehicle or trailer. You must also ensure that you are using appropriate towing equipment, that the towing equipment has been installed correctly and used properly, and that you employ the requisite driving habits. (P. 198)" https://www.toyota.com/t3Portal/document/om-s/OM04025U/pdf/OM04025U.pdf
    Junkhead and CygnusX191 like this.
  5. Oct 19, 2020 at 8:02 AM
    #85
    specter208
    California
    80mph is too fast. It’s unsafe and you are drastically reducing your mpg .
    b_r_o, Boghog1, Lt. Dangle and 5 others like this.
  6. Oct 19, 2020 at 8:06 AM
    #86
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    per the manual you should be towing in s4 with ect on.....
  7. Oct 19, 2020 at 8:36 AM
    #87
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    OP forgot to mention
  8. Oct 19, 2020 at 8:39 AM
    #88
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I'll be spending hours stabbing out my mind's eye now........trying to erase the mental image.......:annoyed:
    GreyBaldTaco, Junkhead, Chew and 3 others like this.
  9. Oct 19, 2020 at 9:08 AM
    #89
    JCT86
    JCT86 Active Member
    2017 Tacoma TRD Off Road
    I bought a 3500 lb travel trailer this summer, and have towed around 5000 miles with it already. I have found that the drag created by the profile of the trailer affects the performance much more than the weight. Throw in a headwind and it can make for a miserable ride.
  10. Oct 19, 2020 at 9:13 AM
    #90
    pdenajim
    pdenajim Well-Known Member
    Jim
    Pasadena, MD
    2017 Inferno Tacoma TRD OR DCSB
    Black MBRP dual exhaust, aftermarket TRD Pro grille, AVS dark smoke hood deflector & dark smoke vent visors, BedRug, BAK Industries Revolver X2 bed cover, aftermarket TRD Pro Tail light assemblies (DEPO), orange vinyl decals on engine cover, door sills, and glove box, LED headlights & fog lights, KICKER speakers, piano black tailgate TACOMA inserts, center console organizer tray, black stainless steel licence plate frames, smoked license plate "protectors", ME-SO Customs Ultimate LED mirror turn signals, Ultimate Dome Light, V2 Map Lights & coin holder, Toyota bed extender, Pop & Lock Power Tailgate Lock, Fortin EVO ALL Plug & Play Remote Start, TRD PRO headlights, Redline Hood Struts, FJ Cruiser 2007-2014 TRD Pro SEMA 17" MATTE GRAY Alloy Rims, COOPER DISCOVERER S/T MAXX 255/80-17 Tires LR E, Gen 2 TRD Pro Suspension, 2" AAL, TRD Pro CAI, Mobtown sliders and full aluminum skids, ARB Safari snorkel. On deck waiting installation: under hood LED lights, bed, U-Bolt flip, Sport Hood, passenger door touch sensitive door handle. Future Mods: "Always On" console USB power mod, "Default On" ECT Power mod, LED lights strips inside the bed, diff vent extension
    OVTune would help quite a bit.
  11. Oct 19, 2020 at 9:16 AM
    #91
    BillsSR5
    bill
    2014 SR5
  12. Oct 19, 2020 at 9:17 AM
    #92
    Knute
    There goes my other eye........................:annoyed::annoyed::sick::sick:
  13. Oct 19, 2020 at 9:18 AM
    #93
    Gen3TacomaOBX
    S
    11 mpg is NOT normal for the trailer pictured on what OP described as level ground.
    Anton338 and CygnusX191 like this.
  14. Oct 19, 2020 at 9:28 AM
    #94
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    I only towed a trailer one time with my Tacoma and that was enough. I really didn’t like how my 15 got blown around on the interstate. Traded it in for a full size, went a couple years, got Tacoma fever again and got a 2018 and then realized I had the same issues.
    Tacoma’s are great in my experience for in town and highway. Towing and interstate are quite the struggle.
    I get 20mpg pulling my bass boat every weekend now if that makes you feel better OP.
    Junkhead and medic2230 like this.
  15. Oct 19, 2020 at 9:29 AM
    #95
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It is if OP is trying to drive 80mph in 6th gear with that trailer :crazy:
  16. Oct 19, 2020 at 9:41 AM
    #96
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    :rofl:
    CygnusX191 likes this.
  17. Oct 19, 2020 at 9:43 AM
    #97
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Niiice:fistbump:
  18. Oct 19, 2020 at 9:47 AM
    #98
    Knute
    The Tacoma is a 1/2 ton truck. It is a mid-size truck with a fairly short wheelbase and narrow stance.
    Any full-size truck with a V-8 will handle pulling a trailer better and with less trouble than a Tacoma due to power, wheelbase and wider stance.
    We pulled a folding camper, loaded near 4000 lbs with a Ninnivan, TrailBlazer, Sonoma, Sierra 2500HD w/6L. All were able to pull. The TrailBlazer was the most squirrely because short wheelbase and soft suspension. The Sierra didn't know the camper was there.
  19. Oct 19, 2020 at 9:51 AM
    #99
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  20. Oct 19, 2020 at 9:54 AM
    #100
    jwrendenver
    jwrendenver Member
    2018 tacoma DCSB
    you should have bought a manual!
    Junkhead and tktv like this.
