Should have bought a half ton
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wire4Money, Oct 18, 2020.
  1. Oct 19, 2020 at 9:57 AM
    #101
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Since when is the Tacoma a 1/2 ton? o_O
    awesomeandy013 likes this.
  2. Oct 19, 2020 at 9:59 AM
    #102
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    It's not but he's going to say that some models have 1000+ of payload so its a half ton.
  3. Oct 19, 2020 at 10:00 AM
    #103
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Pop Quiz: How many pounds is a ton? ; )
    Anton338 and GreyBaldTaco like this.
  4. Oct 19, 2020 at 10:01 AM
    #104
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    That my friends is the definition of a 1/2 ton truck.
    Quiz answer.....2000 lbs
    GreyBaldTaco and Gen3TacomaOBX like this.
  5. Oct 19, 2020 at 10:07 AM
    #105
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    General nomenclature, half ton truck means full size truck. Like a 1500. The Tacoma is still a midsize truck, would be qualified as a quarter ton. Obviously the actual names of the trucks doesn't mean a whole lot anymore since an F250 can carry way more than 1,500 lbs etc.
    b_r_o likes this.
  6. Oct 19, 2020 at 10:09 AM
    #106
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    yes it is, especially for someone trying to tow with cruise on and leaving the trans in auto. Also, your efficiency measure (in this case mpg) does not drop in proportion to the increase in trailer weight. For example, let's say I pull an empty trailer that weighs 1000 lb one hundred miles on flat ground on interstate. I get 13 mpg. Once there I load the trailer with 2K in rebar so the 100 mile trip back I get 12 mpg, I also load it so the tongue weight is the exact same as it was empty. This is perfectly normal because, on flat ground, once you get the load moving, the only real addition the truck knows about is rolling resistance of trailer tires. The aerodynamic drag is the same and we have taken the angle force vector out of the equation by keeping it on flat ground.
    So to summarize, you lose a lot of mpg just hooking up a trailer but most of the time, the heavier you go does not mean a proportional drop in mpg.
  7. Oct 19, 2020 at 10:14 AM
    #107
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  8. Oct 19, 2020 at 10:17 AM
    #108
    Gen3TacomaOBX
    S
    Heh. So you're saying 11 mpg is indeed the average expected mpg when towing a 1k lb trailer?
    It does not match my experience towing any of the following:
    • 5 x 10' landscape trailer (anywhere from empty to a 1500 lbs load.)
    • 2600 lb travel trailer
    • Steel car trailer loaded with shop equipment.
    Then again.. I don't drive with a trailer the way I drive when it's empty nor do I expect it to accelerate the same way. 11 mpg might be normal either dragging a brake, towing inclines or not having a clue about energy management. :crapstorm:
  9. Oct 19, 2020 at 10:23 AM
    #109
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I think you hit the nail on the head with the last point ;)
    When I tow, I try really hard to get the best mpg possible. However, I have hooked up and drove like a bat outta Hell to get to the destination. That's when 11 mpg is common.
  10. Oct 19, 2020 at 10:44 AM
    #110
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    The speed limit on I-90 across South Dakota is 80 mph, and I would not call it unsafe for most drivers and modern vehicles.
    No kidding about the mpg... 14.9 for a stock, unloaded Tacoma.
    Front sight and DogStar84 like this.
  11. Oct 19, 2020 at 11:11 AM
    #111
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Once drove an F350 flatbed from Sacramento to Houston. There was an 80mph stretch of I10 where I really opened the taps and cruised. It only lasted a little bit when I realized I was having to stop and fill 25-30 gallons every 200 miles. If I just dropped it down to 65mph the tank range doubled.
    It might be safe for most cars to travel at 80, but not every car is designed for it.
    I actually did a stretch of I90 this summer. Even unloaded, with the trailer and gear left behind at the campsite I chose not to exceed 70mph with the Tacoma. The cool part was discovering that if I just hung out in the right lane and let everyone pass, I had fewer interactions with idiot drivers, and I was far less irritated overall. Every 100 miles takes 15 minutes longer but saves just over 2 gallons. 4 dollars saved, which doesn't seem like much. But the stress and aggravation that you save very much is.
  12. Oct 19, 2020 at 11:14 AM
    #112
    TopQuark
    TopQuark Well-Known Member
    Andrew
    Shelton, WA
    2021 Tacoma TRD OR DCLB AG 4x4
    Maybe it’s just me but it tows pretty much how I would expect with the torque curve that the V6 has stock. With my 2800lb Rpod and fully loaded I get 11-14 mpg in S4.
    Just keep it under 70mph and enjoy the sights.
    Whiskeyjack, pdenajim, grogie and 2 others like this.
  13. Oct 19, 2020 at 11:19 AM
    #113
    jjglass535
    jjglass535 Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    I hear you, I've almost had enough too. I just have a dirt bike and gear in the back and my truck shifts every two seconds no matter what I try.Cruise control shouldn't even be an option on these truck as it's completely useless
    NMTrailRider and WarrenG like this.
  14. Oct 19, 2020 at 11:28 AM
    #114
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    You are supposed to tow in S4 and ECT on, keep it outta cruise and don't expect it to perform or drive like it does without a trailer.. Tow in those overdrive gears and shorten the life of your transmission. .If you want to get better fuel mileage run it under 65 etc. But the owners manual has all that in there for reference. The truck is performing relative to the operator input. They are not the best towing vehicles....they are not end all be all trucks, but for most peoples truck usage, they are pretty versatile with a little bit of thought.
  15. Oct 19, 2020 at 11:36 AM
    #115
    CheapLaborTJ
    CheapLaborTJ Well-Known Member
    b_r_o, jdiru and CygnusX191 like this.
  16. Oct 19, 2020 at 11:37 AM
    #116
    itr1275
    itr1275 Well-Known Member
    Jerold
    San Jose CA
    '00 Tacoma TRD Off Road
    Icon Coilovers, Daystar Shackles. Sliders.
    I thought the Taco is a 1/2 ton?
    Mileage sounds right. I normally get about 16 MPG.
    My taco is a 2K with the 3.4L Auto. I towed a trailer that size to Woodland from San Jose empty and back loaded with a tool box with had no issues. Didn't even know it was there for the most part. Now it was mostly flat freeway and I only have 4 (3+overdrive) speed auto. Towed a few other things too with no problems.
    If you have lots of hills and in town traffic it's not much fun. But given the modern electronics trying to make all kinds of "smart decisions" to optimize mileage, I wouldn't expect to use the cruise control. My newer 4runner has a mind of it's own.
    It's no secret that Toyota is loosing market share because of the drive train. The Ranger and Colorado have better power, but they are not Toyota quality.
  17. Oct 19, 2020 at 11:39 AM
    #117
    itr1275
    Jerold
    San Jose CA
    I think this is a quote from the owner's manual on page 197?
  18. Oct 19, 2020 at 11:39 AM
    #118
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Are you serious here? I drive on posted roads at 70 mph, everywhere. Reading comprehension low, towing, sorry.
  19. Oct 19, 2020 at 11:40 AM
    #119
    grogie
    Sorry for any confusion. I was originally referring to my Tacoma driving 80 mph and it's low mpg... not in regards to towing. With that being said on I-90 through South Dakota, semi trucks and other vehicles that were towing were all going over 65 mph. I was being passed by a few full-size trucks towing ATVs when I was at 80 mph.
    Boghog1[QUOTED] likes this.
  20. Oct 19, 2020 at 11:41 AM
    #120
    grogie
    Nice! What model is your R-Pod?
