Should I be concerned?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tanner.b16, Jan 31, 2023.
  1. Jan 31, 2023 at 2:24 PM
    Tanner.b16
    Tanner.b16 [OP] Well-Known Member
    Tanner
    South Carolina
    clean 07’ Tacoma
    Hey guys, Noticed my wheel come VERY close to the caliper. Paper thin in between. Should I be worried?
  2. Jan 31, 2023 at 2:29 PM
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    Yeah, I would be a little bit worried.
    But what are you going to do, return the rim or something? lol
    ToyoTaco25 and 12TRDTacoma like this.
  3. Jan 31, 2023 at 2:31 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Way to close...probably hear it rubbing when turning hard
  4. Jan 31, 2023 at 2:33 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Cheap. Easy. Wheel spacers
    But the offset of the rims are a little off
    Tanner.b16[OP] and 12TRDTacoma like this.
  5. Jan 31, 2023 at 2:51 PM
    AustinWest
    AustinWest The Amazon Special
    South Carolina
    2006 Tacoma - DCSB - 4WD - Manual
    Wheel spacers are going to be your cheapest way to go. That being said, DO NOT buy anything except for bolt-on hub-centric spacers. The thin plate spacers are dangerous af.
  6. Jan 31, 2023 at 3:01 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  7. Jan 31, 2023 at 3:07 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Maybe touch the caliper lightly with a grinder or even a file by hand.
    FishaRnekEd and Steves104x4 like this.
  8. Jan 31, 2023 at 3:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Spidertrax or Bora Hub/ Lug centric wheel spacers are the fix here. Anything short of that is asking for potentially dangerous failure, including leaving it alone as currently is.
  9. Jan 31, 2023 at 3:44 PM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    Sell these and buy some different ones.
  10. Jan 31, 2023 at 3:45 PM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    I don’t hear it at all, i’ve had them on for about 10k miles. It just concerns me
    SR-71A and HondaGM[QUOTED] like this.
  11. Jan 31, 2023 at 3:45 PM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    i’ve heard some scary wheel spacer stories
  12. Jan 31, 2023 at 3:46 PM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    huh centric ok to run? wouldn’t have any issues?
  13. Jan 31, 2023 at 3:48 PM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    Are wheel spacers safe? I’ve heard bad stories of them breaking.
  14. Jan 31, 2023 at 5:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Hub centric like bora or spidertrax is fine. I ran Boras for 100k with no issues at all. I even stopped checking the torque during tire rotations after a year or so
    That being said, if you've been on those wheels for 10,000 miles and there's no scratches on the caliper you're probably fine
  15. Jan 31, 2023 at 5:08 PM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    Thanks man! After I just lifted the truck it looks like the tires are farther under the body now. Might get some anyways.
    HondaGM likes this.
  16. Jan 31, 2023 at 6:17 PM
    RockfishTaco
    RockfishTaco Well-Known Member
    Nate
    Massachusetts
    I don’t see an issue.. if it clears, it clears.
    I did have a issue with brake pads actually rubbing on some wheels back when I used to be into lowering Volkswagens and being a cool kid. took a grinder to the pads and made clearance and never had an issue.
  17. Jan 31, 2023 at 6:24 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Well… if it hasn’t touched by now I don’t guess it’s going to…just mighty close
    SR-71A likes this.
  18. Jan 31, 2023 at 7:11 PM
    TacoTuesday1
    SD CA
    run a correct wheel
    I wonder what the best spacer is and the name of it. I’m guessing it’s those blue ones I see everyone run.
    Idk about these comments on safety. It bolts to the hub. The wheel bolts to it.
    It’s literally recommended by reputable companies like Archive and Accutune when running rear shock relocate tower.
    and, 6 lugs is a lot. As opposed to 5
    Tanner.b16[OP] likes this.
  19. Jan 31, 2023 at 7:46 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Not my truck and I don't have to drive it, but, the clearance between the factory wheel and caliper on my 2015 sport is .025. I would be concerned.
  20. Jan 31, 2023 at 7:58 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    If it clears, it clears. If it starts touching in the future your wheel bearing is probably going out. I have about that much clearance with my methods on my ‘07 and maybe a smidge more on my 2019 Tahoe that has a factory big brake kit. Definitely wouldn’t do spacers for this!! Rather grind the outside of the caliper a little bit, but imho not needed in your case
    SUMOTNK likes this.
