Should I be running rear axle shims?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Oct 18, 2013.
  1. Oct 18, 2013 at 4:19 PM
    TacomaJPP
    TacomaJPP [OP] To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I have a 1.5" AAL on my rear axle. Should I be running a shim kit to adjust my pinion angle to compensate for the lift? I have a 2 or 2.5 degree kit, just never installed it. Thoughts?
  2. Oct 18, 2013 at 4:34 PM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    Does the truck drive fine right now? If so, don't mess with it.
    FWIW, I installed OME Dakars and the AAL (OME D6XL) which gave me ~4 inches of lift in the rear. I didn't shim anything or drop the carrier bearing and my truck drives smooth. I did extend the rear brake line and install an exhaust hanger to drop it down lower, but that is all for the rear.
  3. Oct 18, 2013 at 4:35 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Got any vibrations? I put a 3 leaf AAL on without shims. I get vibration between 23-27 mph. The shims would help.
  4. Oct 18, 2013 at 6:31 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    My truck has always had vibes at 65...always.
    Since the lift, it is more severe and the vibes are between 60-72.
    I replaced the carrier bearing 10,000 miles ago and it didn't help. I tried a Beefed Taco carrier bearing spacer and it didn't help either.
    Now I'm hearing a very light "popping" sound from the cab above 50mph. So, I put my GoPro under the truck (can't post vid right now) and the pop sounds more like a "roar" and is definitely driveline related. The roar has a frequency of twice per second.
    The only concerning thing I noted from the vid, is I seemed to see the driveshaft have a wobble close to the carrier bearing. Maybe it is out of alignment.
    I guess I'm going to jack the truck up on jack stands, loosen the carrier bearing, and get the wheel speed up to 60 mph and allow it to self-align and tighten.
  5. Oct 18, 2013 at 6:45 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    How many miles are on it, i just did u-joint's and it took some vibe's out but i still have a slight shudder around 35 to 45mph and im stock. Have always had a little vibe, gonna slap a new carrier bearing on it soon. Buddy of mines son works at dealership and can get me the bearing for $140.
  6. Oct 18, 2013 at 6:48 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    210k and I pull a boat...a lot.
    I bought my CB from partznet.com for $147, Genuine Toyota.
  7. Oct 19, 2013 at 6:05 AM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    So, I'm guessing its time for new u-joints and a double cardan rebuild?
  8. Oct 19, 2013 at 6:30 AM
    sgrappone
    sgrappone Well-Known Member
    Scott
    Moncks Corner, SC
    04 AC 4X4
    Sounds like you may have a bad u joint. I had vibes after installing my dakars on my 04 ext cab. 2* shims eliminated my vibe issues.
  9. Oct 19, 2013 at 6:39 AM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    I guess I will pull the driveshaft and check the slop in the joints and throw the axle shims in. Process of elimination at this point.
  10. Oct 19, 2013 at 6:40 AM
    jandrews
    '09 FourDubDee TRD OR
    Carrier bearing adjustments solve most vibes. The problem is most people do it incorrectly with pre-made spacers. This idea CAN work if you've already determined what size spacer you need, but most don't. They just buy the premade shit off the shelf and assume that the same drop height works for all lifts.
    Tell me, if lift height can be anywhere from 1" to 6", why wouldn't CB drop distance be just as variable?
    The correct way to implement this fix is with a little diagnostic testing. Get 30 or so grade 8 washers and start shimming your carrier bearing down. Shim it down two washers, then test drive. Shim again. Test drive. At some point, you will notice your vibes decreasing. Keep shimming in that direction until your vibes are gone or starting to increase.
    Measure the drop at the "least symptomatic" height.
    Then do this:
    http://www.tacomaworld.com/forum/2nd-gen-builds/43696-begins-miss-blue-32.html#post5444164
    Or have some spacers milled to the measurement you have determined.
    THAT is the correct way to address this issue.
    Let me suggest that you avoid axle shims like the plague. All the options on the market are shit and prone to breakage.
    At high mileage, depending on maintenance, you may also have a u-joint issue. Check that out as well.
    andrewtheadventurer likes this.
  11. Oct 20, 2013 at 4:25 AM
    sgrappone
    Scott
    Moncks Corner, SC
    04 AC 4X4
  12. Oct 20, 2013 at 5:51 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    I decided to shoot some grease in all of the zerks. The one for the slip yoke took about 10 or 15 shots. The more I have driven it, the quieter it has became and it is amazingly smoother believe it or not.
    Today a buddy and I jacked the truck up and felt absolutely zero slop in my u-joints and DC joint.
    I do have some backlash in my driveline. It looked to be about 3/32" of rotation. Is that normal?
  13. Oct 20, 2013 at 6:09 PM
    jandrews
    Tis.
