Should I be using premium gas in my Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco386, Jun 19, 2021.
  1. Jun 24, 2021 at 10:09 AM
    #201
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    I have only run premium in my truck since I picked it up. I average somewhere between 28 and 37MPG while driving around the city on 35s with stock gearing and no tune.
    Obviously I am joking, about mileage and mods, Dudes on jeep forums make idiotic claims like that all the time. I do run Ethanol free premium but only because of the following reasons:
    1) I only commute to work 3 days a week, before that I worked from home full time, and my previous job was <5 miles from my house. So I don't go through gas at an alarming rate and don't want to worry about the hygroscopic properties of ethanol blends.
    2) I get to use the same fuel/cans for everything I own, small engines definitely benefit from ethanol free fuel.
    3) No more wasting money on additives/snake oil for ethanol blend fuel, yea it's a wash after you take into account, (with gas prices where they are right now it is about $14 more per tank) the higher price but it is less trips to the store and no wasting time mixing the additives in.
    4) I am sure there are more reasons but that's really all i can think of for now.
    I am sure I would be fine running 87 with ethanol and dumping in additives. If I could get ethanol free 87 I would happily run that in the truck.
    Other ways to waste money for peace of mind include: running Mobil-1EP with BG MOA and changing oil every 5k, (did it on my last vehicle and the motor still burnt the valve seats at about 140k), running Amsoil signature series and and Amsoil filter and changing oil every 5K, doing that on this truck because I don't want to deal with additives, I don't put many miles on the truck, and the included filter housing drain tube works great. Add a fridge to the bed of the truck for the 2 camping trips a year and occasional tailgating.
  2. Jun 24, 2021 at 10:23 AM
    #202
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    Ok two things here. One - how did I “impose” my experience? I did exactly what you did by simply relating my experience and even said I don’t care what anyone else does with their money. Go back and read my words carefully then get back to me if you like.
    Two - last time I checked 87 is not 93. If it says use 87 that doesn’t mean anything higher is better. It simply means the engine requires at 87 to run efficiently and they dont recommend going lower. I think you’re making the mistake of thinking that if 87 is good then anything higher is better. It doesn’t work that way. But you do you.
    By the way, around here, the standard regular gas is 86. You can’t get anything else without jumping up to the 90’s so 86 is pretty much what everyone uses, including myself and I have noticed ZERO difference between it and anything higher including 93. So again, If you think 93 makes a world of difference knock yourself out. It’s your money.
    I will say that IF I did notice a difference I would use the higher octane (not “better” or “premium” by the way. The only vehicle I presently have that requires it - and I definitely do see a difference if I don’t use it - is my Indian Springfield which requires it or the engine knocks. That’s the way it was designed.
    Thatbassguy likes this.
  3. Jun 24, 2021 at 10:32 AM
    #203
    Dryfly24
    George
    NM
    Reading though this and other threads like it, I’m beginning to think people get so caught up in it on a personal level because they like to think they are justified in spending the extra money then get irate when people basically tell them they are just wasting it.
    Personally I don’t give a rat’s ass. People tell me I waste money on expensive fly rods when a much cheaper rod will do the same thing. Are they right? To an extent yes performance wise, but I don’t get the personal satisfaction from a less expensive commercially manufactured plastic rod as I do from a handmade cane rod. Even when on occasion the plastic rod will cast circles around my cane. To each his own but it’s my money.
  4. Jun 24, 2021 at 10:34 AM
    #204
    B1gDaddyT
    B1gDaddyT Well-Known Member
    2019 Cement Taco TRD OR 4x4 DCSB
    11 pages!?! I can't believe this thing is still going....
  5. Jun 24, 2021 at 10:42 AM
    #205
    Dryfly24
    George
    NM
    Octane and oil threads… :D
  6. Jun 24, 2021 at 10:54 AM
    #206
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    Don't forget the shifting and ECT threads
  7. Jun 24, 2021 at 10:59 AM
    #207
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Completely agree lol. I do run premium (more for the ethanol free benefit) on my more.... high performance toys.
  8. Jun 24, 2021 at 11:52 AM
    #208
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Man, I have been gassing up my FJ for over a decade with rot-gut 87 fuel and never noticed that 91 octane only sticker! Whoops! :)
    Daves300[QUOTED] likes this.
  9. Jun 24, 2021 at 12:16 PM
    #209
    Rick4657
    Rick4657 Well-Known Member
    Rick
    Iowa
    2019 Red TRD OR
    I drove a Lexus RX which uses the same 3.5L engine as the Taco for ten years that was supposed to use Premium, I never bought Premium. I gave the Lexus to my daughter when I bought my Taco. The Lexus never had any issues and is still going strong at 145,000+ miles.
    Dryfly24 and Thatbassguy like this.
  10. Jun 24, 2021 at 1:25 PM
    #210
    Itchyfeet
    Itchyfeet Well-Known Member
    I ran 91 in mine not because I wanted too, but I didn't want it sitting with 10% ethanol in it for weeks at a time as found in lower octanes. I drove my 18 maybe 300 hundred miles a month on a good month.
    I doubt there was any performance advantage.
  11. Jun 24, 2021 at 2:00 PM
    #211
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I'm not an accountant, but I did stay at a Holiday Inn once.
    I've got a stock ACLB with 265/65-17 size Goodyear Wrangle tires. I want something different to increase my fuel mileage and be aggressive on pavement......What do y'all recommend???? If I stay with the same size will they rub???
    Good grief.....this discussion has morphed into ridiculous, passed ludicrous and gone plaid.
    Burn diesel or av fuel or methanol or nitrous or methane or.......... the Tacoma needs a minimum of 87 Octane. Burn what you want, it only burns your wallet quicker.
    zoo truck, Thatbassguy and OrangeRa1n like this.
  12. Jun 24, 2021 at 2:35 PM
    #212
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I see what you did there. :rofl:
    Dryfly24 and echoboom like this.
  13. Jun 24, 2021 at 4:57 PM
    #213
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Actually adding ethanol to lower octane gasoline's will increase the octane level. Its mostly how 87, and on up are blended.
  14. Jun 24, 2021 at 5:04 PM
    #214
    Itchyfeet
    Not in my state anything that is 91 is clearly marked on the pump ethanol free.
  15. Jun 24, 2021 at 7:46 PM
    #215
    VanGo3
    VanGo3 Modern vehicles are ugly.
    Northern California
    20 SX AC 4x4
    Mostly dust and dirt.
    Just wait until I start yet another thread ABOUT WHAT OIL IS BEST BWAHAHAHA!!
    Dryfly24, OrangeRa1n and Thatbassguy like this.
  16. Jun 24, 2021 at 8:23 PM
    #216
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Peanut oil is king. Two tanks of that and you’ll never put gas in your engine again, guaranteed.
    soundman98, Dryfly24 and OrangeRa1n like this.
  17. Jun 24, 2021 at 8:27 PM
    #217
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Knock knock.
    Who’s there?
    No one.
    Fill’rup regular…
    BSFord, The hammer and OrangeRa1n like this.
  18. Jun 24, 2021 at 8:44 PM
    #218
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Premium hurts my feelies.
    Hi-Test for me
    "fill, 'er up with ethyl " is the way it should be .
  19. Jun 25, 2021 at 7:03 AM
    #219
    zoo truck
    None
    Only way to get ethanol free gas in our state is to buy a barrel of race fuel.
  20. Jun 25, 2021 at 8:55 AM
    #220
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Unexpected benefit, you can drink it on skid row. :facepalm:
