Should I be using premium gas in my Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco386, Jun 19, 2021.
  1. Jul 6, 2021 at 2:05 PM
    #241
    SilverSkyTRD
    SilverSkyTRD Well-Known Member
    I live my life 5 gallons at a time....
    Shippe, OmahTako, ToyoTaco25 and 2 others like this.
  2. Jul 6, 2021 at 3:13 PM
    #242
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Once tried klotz nitro additive in an old lawnmower...ran really good for a couple minutes then sized up.
    Barsoom and Thatbassguy[QUOTED] like this.
  3. Jul 12, 2021 at 1:27 PM
    #243
    Tacoma_Noob
    Tacoma_Noob Member
    2021 Cement Tacoma TRD OR
    I remember when I used to run with 110 octane fuel. One day I realized if you can't spare a few pennies to go up to 118 octane fuel, maybe you should consider changing your vehicle. I only run 118 octane and haven't had any problems. 500k+ miles
  4. Jul 12, 2021 at 1:32 PM
    #244
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    I use the one with the green nozzle.
    Green means good & go fast.
    Gunshot-6A, Barsoom and Tacoma_Noob like this.
  5. Jul 13, 2021 at 8:29 AM
    #245
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    And green means good for environment. Plants love the green exhaust!
  6. Sep 8, 2021 at 10:28 PM
    #246
    BrysonHart
    BrysonHart Active Member
    Bryson
    2020 cement taco
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
  7. Sep 9, 2021 at 6:20 AM
    #247
    2pei
    2pei Well-Known Member
    Scott
    Oregon High Desert
    03 Tacoma
    mild lift, suspension & assorted badassery
    folks that run premium and pressurize thier tires with nitrogen are funny
    Thatbassguy and maineah like this.
  8. Sep 9, 2021 at 7:52 AM
    #248
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    the difference between 87 and 91 is how advanced the ignition timing is. it does advance more on 91 versus 87. whether it's worth it or not, is up to you.
  9. Sep 9, 2021 at 12:12 PM
    #249
    zoo truck
    None
    If thats the case...why does my truck run worse on 92 vs 87? Gotta be other factors involved.
  10. Sep 9, 2021 at 4:13 PM
    #250
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    My 2nd gen runs good with premium in it. 370,000 miles and it still gets up and goes when I need it to.
  11. Sep 9, 2021 at 4:29 PM
    #251
    Watacoma
    Watacoma Well-Known Member
    luther
    2019 Cement TRD Offroad
    I will with non ethanol 92. It runs better on 92 than 87. The low rpm light load run smoother, like when the truck is doing 40mph at 1100 rpm, and then you slightly accelerate and it doesn't downshift.
    Yes I know it doesn't make any sense but I've switched back and forth, multiple times, both my and my gf felt the difference.
    I would love to data log the truck and see if there's a timing difference, somthing is causing it to run better.
    JJ Diablo likes this.
  12. Sep 9, 2021 at 4:33 PM
    #252
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Nope . Unless an engine requires it , they are designed to perform flawlessly on 87. There is no quantifiable benefit. But it makes some people feel better. Its been argued for years so whatever.
    91 / 92 is better fuel if your engine is setup to perform better on it , yes. But thats not the case with Tacomas.
    zoo truck likes this.
  13. Sep 9, 2021 at 5:10 PM
    #253
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I'm getting help with tuning the timing and the valve timing and what I can see is that stock ecu timing is too advanced compare to what I'm testing. I know that 87 performs adequately, but in 5th, 6th gears under 60-75% load and rpms around 2000 on stock ecu I was getting -6 -7 on knock feedback and the ecu would retard timing by a few points.
    Besides timing, there is valve timing that affects the performance.
    Just my observation...
  14. Sep 9, 2021 at 5:18 PM
    #254
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    118, 119, whatever it takes.
  15. Sep 9, 2021 at 5:28 PM
    #255
    zoo truck
    None
    I would think these tacoma's are tuned properly by the manufacture to run their best on 87. Anything higher you won't see any difference to a point the octane used is so high performance suffers. At least my v6 feels that way. Seems 89 e10 is the cutoff in higher octane before the truck runs worse on anything higher.
    I guess for some its the old adage that if it runs good on 87 then more octane is much better.
  16. Sep 9, 2021 at 5:30 PM
    #256
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Since when did a mechanical device develop "feelings"?
    Bushed likes this.
  17. Sep 9, 2021 at 5:42 PM
    #257
    Tripod1404
    Tripod1404 Annihilator tripod
    Well... actually your fuel economy will improve so it will cost you less money overall. With 118 octane, you will get at least 300 miles per gallon.
  18. Sep 9, 2021 at 6:49 PM
    #258
    Watacoma
    luther
    Yes people can poke fun all they want; I've been tuning my personal fun cars using dsmlink and hondata for 15 years now, I'm not some idiot who simply thinks the more expensive gas equals better.
    This engine runs better at those low rpm/ light to mid light loads. If I had to guess there's a bit of low speed pre ignition and the computer is pulling a bit of timing under very small rpm window, above 2k rpm's Not noticeable. I'm sure I could prove this if I had the ability to data log but I'm not going to spend the money, as it is 92 octane isn't that much more expensive.
  19. Sep 10, 2021 at 5:30 AM
    #259
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I propose a race of two identical Tacomas with different fuels. Our local airport sells av gas, last time I looked it was $ 5.89 a gallon and 100 octane ethanol is 113 octane. Light air craft pilots have the ability to alter the fuel mix using ex gas temp or air fuel ratio. There is more heat energy in 87 than 94 octane fuel. Days are long gone when you could twist a distributor to advance the timing.
    Thatbassguy likes this.
  20. Sep 10, 2021 at 6:28 AM
    #260
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Based on below sure seems like a Tacoma could benefit from it. I don't personally think running 93 is worth it (its a dollar more a gallon here). But pretty clear evidence a higher octane can help in some situations.
