Should I be using premium gas in my Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco386, Jun 19, 2021.
  1. Jun 20, 2021 at 4:46 AM
    #41
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    my wallet says no
    bigsmirt likes this.
  2. Jun 20, 2021 at 4:49 AM
    #42
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I agree if the truck is stock with no aftermarket tunes, theres no reason to use a higher grade gasoline than 87. I tried a few tanks of 89 mid grade, and 92 premium....the truck either ran the same, or worse when premium was used.
  3. Jun 20, 2021 at 4:55 AM
    #43
    mhornco
    mhornco Well-Known Member
    Ran 91 and got better gas mileage due to weight savings. My wallet was lighter.
  4. Jun 20, 2021 at 4:58 AM
    #44
    saskcan
    saskcan Well-Known Member
    Curtis
    Saskatchewan
    2010 sport 6spd
    some accessories
    I use to do a 270 mile commute every few weeks and tested 87 vs 91 occasionally (more so in the winter as my fuel economy was crap in winter) what I noticed I gained an equivalent MPG equal to the extra cost. So 91 octane gives me more range on my tank without it costing any extra not sure if that's true in the summer (I have 2ns gen V6)
    VTCAL and rdgm71 like this.
  5. Jun 20, 2021 at 5:17 AM
    #45
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    When I bought my truck in 2009, I asked my mechanic is there anything I need to do differently with this truck than my old one? His response was; run premium gas in it. It will save you from having to replace sensors early. So I have used premium gas since the second tank. 364,000+ miles later, it still runs like a young truck.
    I found a tread on here about cleaning the throttle body. People were posting pictures of their throttle body before and after cleaning at 60,000-80,000 miles. I had 200,000 on mine, so I took it off to clean. It was cleaner than others with less miles. I feel the premium gas has a lot to with how clean it was.
    I my opinion premium gas is like synthetic oil, better quality better results.
  6. Jun 20, 2021 at 6:15 AM
    #46
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Depending on the quality of the actual fuel available in your area, your 87 might actually be closer to 85. The 92 might actually be closer to 87. So, your results could be just finding fresh quality fuel.
    Junkhead and Thatbassguy like this.
  7. Jun 20, 2021 at 7:27 AM
    #47
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    That was certainly true, some time ago. Today with the ability of modern engine/ecu's ability to vary ignition timing and valve timing by a considerable amount, it is no longer the case. I would bet that with the toyota(and other makers) engine the variable timing will self adjust between 85 and 93 ish. That is the range of standard fuel.
  8. Jun 20, 2021 at 7:27 AM
    #48
    zoo truck
    None
    Thats funny was told just the opposite if running premium fuel when the engine manufacture calls for 87....told me premium fuel can cause the o2 sensors to fail earlier. Imo, its more about how fresh your fuel is. We did an emission test on a 22R powered toyota back in the day before, and after with the fitch fuel catalyst product....was amazed how it kept gas as fresh as the day you got it from the pump. Month old fuel was already showing more emissions then the same gas that was treated with fitch a moth earlier.
    ret42 and POOLGUY[QUOTED] like this.
  9. Jun 20, 2021 at 7:54 AM
    #49
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    This story starts with a profound misunderstanding of fuel and laws of physics, and ends with a placebo effect summery of perceived benefit where none exists.
    Don't mean to hate, this is the internet after all and you know what they say about opinions.
    OP, don't waste you're money, just run what the truck was designed to use, 87.
  10. Jun 20, 2021 at 7:56 AM
    #50
    Unsunghero
    Unsunghero Well-Known Member
    2021 Metallic Grey TRD Off road
    What about 89 octane? Had a co-worker mention this reduces carbon buildup in the engine?
  11. Jun 20, 2021 at 7:58 AM
    #51
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Nonsense. Ignore coworker's anecdotes.
    OrangeRa1n, Blockhead and BSFord like this.
  12. Jun 20, 2021 at 7:59 AM
    #52
    Unsunghero
    kk ty. Gas is expensive enough, I’d rather not spend more if I can avoid it
    Thatbassguy likes this.
  13. Jun 20, 2021 at 8:09 AM
    #53
    RatDaddy
    Roy
    None
    Although I am in the camp that premium is a waste of money in most cases, I will say that if you are in an area that is not so well traveled and happen on a gas station that sees little use, get premium. Gasoline degrades over time and loses octane pts. Sometimes it's not a bad idea to run a point or two higher just because the stated octane may in fact not be correct.
  14. Jun 20, 2021 at 8:26 AM
    #54
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Skip the higher octane gas. I've tried a tankful or two and saw absolutely no difference from the gas I buy at Sam's. Now, if you can find a station in your area that offers it, ethanol free gas will give you noticeably better performance.
    Junkhead, zoo truck and BSFord like this.
  15. Jun 20, 2021 at 8:29 AM
    #55
    rdgm71
    rdgm71 Well-Known Member
    Richard
    Florida
    2018 Black Toyota Tacoma OR Double Cab Short Bed 2WD
    Again the manufacturer doesn’t call for 87 octane, it calls for 87 or higher octane. There’s a difference on that statement that a lot of people don’t seem to see.
  16. Jun 20, 2021 at 8:31 AM
    #56
    rdgm71
    Richard
    Florida
    Sam’s is not considered Top Tier and Toyota recommends Top Tier top quality gas and that’s definitely not what you find at Sam’s. Costco , on the other hand does offer Top Tier fuel.
    Junkhead, DRAWN and BSFord like this.
  17. Jun 20, 2021 at 8:32 AM
    #57
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    One could spin your argument into the fact that said “not so well traveled” gas station likely has premium gas in their tanks that’s much older than the 87 octane, being that most people don’t use premium, it sits in the tank longer.
    Junkhead, BSFord and Bushed like this.
  18. Jun 20, 2021 at 8:33 AM
    #58
    RatDaddy
    Roy
    None
    Good point
    Sure, premium can sit longer, but premium takes longer to degrade in pts as well.
    Junkhead likes this.
  19. Jun 20, 2021 at 8:34 AM
    #59
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    I feel like this topic is covered once a week.
    Higher octane theoretically has a lower energy density. You will never notice the difference. Therefore, there is no benefit since our trucks call for 87. The only time it makes sense is if you are towing on a hot day, as it could reduce the chance of detention (which would still be prevented by the computer by adjusting the timing).
    Ethanol free fuels have more energy density but the difference in price does not justify the change. Ethanol gas will technically keep your engine cleaner than the former. Pretty much all cars are designed to run on ethanol and its a cheap way to increase octane ratings. Ethanol free only makes sense if you are storing the gas (e.g., a boat or car you don’t use often) as it is hydroscopic and will slowly absorb water in the air.
    Putting in higher octane and ethanol free fuel are both “old school” ways of thinking. Older engines did not have anti-knock sensors and had a tendency to detonate depending on the fuel. This is no longer an issue as modern engines can adjust to avoid detonation before it occurs. Likewise, older engines had problems with ethanol drying out the rubbers used in the hoses. Also no longer a problem.
    Put the cheap stuff in and enjoy.
  20. Jun 20, 2021 at 8:35 AM
    #60
    rdgm71
    Richard
    Florida
    People do what they want with their own money. I can’t tell anybody how to spend their money. As far as placebo effect, I’m perfectly fine if it’s my imagination playing tricks with me. The bottom line is my truck drives better and I happen to enjoy more that way even if it’s all in my head.
