Should I be worried....2022 - 2.7L 4wd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Phil_McKracken, Jul 8, 2022.
  1. Jul 8, 2022 at 9:56 PM
    Phil_McKracken
    Phil_McKracken [OP] Member
    2022 Tacoma 2.7 SR 4x4
    SX package
    Hello,
    New 2022 Tacoma SR 2.7L. Checked oil at about 500 miles and really had a hard time finding oil on dipstick between dots. Oil so thin plus bad eyesight made it hard to be 100%. Took it to dealership to make sure. They had to look a couple times also and said it was fine just that 0w20 hard to see on new engine.
    I have been breaking it in very easy. At 1000 miles really had to really get on gas for the 1st time since purchase to merge and heard a metallic rattle, like a heat shield or crackle. Once I let up, noise gone. I could repeat the noise only on VERY hard acceleration not normal driving. When repeating sound days later not nearly as loud as 1st experience. I took to dealer for 1st oil change at 1200 miles and they said everything tight on heat shield. Dealer said it was normal sound from engine break in.
    After oil change, truck still does it but not nearly as bad. That is what I don't understand.
    Should I be worried it was being run on very low oil? Or is it because the 1st time it made noise engine was hot from 2 hour drive in 97F heat causing heat shield to flex?
    Really love TW forum, thanks for any insight.
  2. Jul 8, 2022 at 10:03 PM
    SpeySquatch
    2016 TRD OR DCSB
    Hey Phil,
    I wouldn’t be worried. Check for rocks getting caught up on the heat shield once in a while…happened to me in my 2.4L and my wife’s 2.7L
    these smaller 4-bangers can sound a bit metallic at times because if they way they rev. If you want to use the best oil (from some of my testing) go with Amsoil. A little expensive unless you do a 6-month subscription for $25, then oil is cheaper by 25%.
    I have found my engines to run far better and have cleaner oil after long durations.
    food for thought…
  3. Jul 8, 2022 at 10:04 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You can scuff up the dipstick as it will be easier to read, you can also let the truck rest awhile so the oil drains down out of the dipstick tube.
    pushgears, RustyGreen, Chew and 2 others like this.
  4. Jul 8, 2022 at 10:12 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    do your own oil change next time, drain thoroughly and refill with 5.8 quarts of oil, that'll get you exactly to full without overfilling it for the 4 banger with filter change
    I established that amount on the first couple of oil changes, and I never bother to check engine oil level in subsequent oil changes
    Chew and Phil_McKracken[OP] like this.
  5. Jul 8, 2022 at 10:26 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Lightly sand the lower end of the dipstick with fine sandpaper between the marks seems to be a common recommendation for making it easier to determine the oil level.
    Perhaps the 'rattle' is the result of 'pinging' - what grade of gasoline are you feeding it?
    hiPSI likes this.
  6. Jul 8, 2022 at 10:34 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Those engines are bulletproof.
    Come back in the year 2052 and post images of the odometer ...
    pushgears and Phil_McKracken[OP] like this.
  7. Jul 8, 2022 at 10:34 PM
    Phil_McKracken
    SX package
    Regular 87...I was thinking pre-detonation when it 1st happened because it was so hot, but I can repeat rattle on a cold engine.
  8. Jul 8, 2022 at 10:39 PM
    Phil_McKracken
    SX package
    That was the plan but I read on here the filters are installed way to tight at factory so I figured I would let dealer do 1st one. I plan on doing future oil changes myself with the exception of the 2 free ones from Toyota Care. One odd thing is that the manual says 10k oil change interval but dealer reminder sticker is 5k. I plan on going 5k route as I plan to keep truck along time.
  9. Jul 8, 2022 at 10:42 PM
    Shellshock
    Iowa
    Oil changes are 10k
    “Maintenance” is every 5k aka rotate tires and check fluids
  10. Jul 8, 2022 at 10:43 PM
    malatx
    it was very tight, I tried changing the oil at the first 500 miles, drained the oil and then found out I couldn't loosen the factory oil filter at all. I proceeded just with fresh oil and let it get to 1500 miles and bought specialty oil filter wrench just for that size Toyota filter and managed to get it off later
  11. Jul 9, 2022 at 7:03 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  12. Jul 9, 2022 at 9:50 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'd be more worried about the anemic power the engine puts out for such a heavy truck.
    I guess if worried about not being able to read the dipstick, you could always anodize it blue or black.
  13. Jul 9, 2022 at 10:07 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    give it a few full throttle passes to get the rings to fully seat. make sure everything is up to operating temp before you do this. you already have 1000 miles on it so it's perfectly safe.
    Phil_McKracken[OP] likes this.
  14. Jul 9, 2022 at 3:16 PM
    zoo truck
    None
    At 1000 miles its more than safe. If something was put together wrong, or a defective part, you want it to fail early.
  15. Jul 9, 2022 at 6:37 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
  16. Jul 9, 2022 at 6:42 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I envy you for the no snow, however you folks have a lot more bugs, snakes & creepy crawlies down your way than we do up here in the rust belt.
    zoo truck, hiPSI[QUOTED] and Delta09 like this.
  17. Jul 9, 2022 at 6:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yes we do. Gotta have a bug guy here. But . No salt no snow. Better trade off.
    RustyGreen[QUOTED] likes this.
  18. Jul 9, 2022 at 7:01 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I'm afraid of snakes. :laugh:
    hiPSI[QUOTED] and JGO like this.
  19. Jul 10, 2022 at 6:47 AM
    zoo truck
    None
    Idk, its a crap shoot, either pay for the a/c, or the heating oil. At least we have snowmobiles up here to enjoy the winter.
    hiPSI[QUOTED] likes this.
