Should I be worried?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dfertig84, May 21, 2021.
  1. May 21, 2021 at 5:05 AM
    dfertig84
    dfertig84 [OP] Active Member
    Yesterday I used my 2015 4WD Taco to help unload a 3,500lb pallet of shingles from the back of trailer by putting it 4WD low and pulling/dragging the pallet about 6 foot with ratchet straps out of the back of a trailer. My truck definitely struggled big time to drag that heavy pallet... after it was done I tried to switch my truck back to 2WD but at first it wouldn't switch out of 4WD, the 4WD light just kept blinking. I shut off/restarted the truck and drove a little and after about 4-5 minutes it finally switched to 2WD but it did so with a kind of loud bang noise. I was a little concerned by all this so I drove around my driveway a little and all seemed well, I also tested switching into back/fourth from 2WD to 4WD and that seemed to be working normally again but I didn't sleep to well thinking about it. I wondering if anything like this has happened to anyone else and should I be worried these events?
  2. May 21, 2021 at 5:11 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Sometimes if I haven't used my 4wd much recently it'll clunk when changing back and forth, always seems to go a bit smoother if I make sure I'm in a straight line, moving, and let off the gas when swapping to 4H. When swapping to 4L from 4H, stop, put the truck in neutral, then swap to 4L. Same process going back to 4H from 4L.
  3. May 21, 2021 at 5:11 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Normal, it just sounds like it was a little bound up. It happens, next time try reversing a little, drop it to neutral for a second, then drive forward / rinse / repeat to get it to unstick.
    For safety I have to mention: if you are going to pull with ratchet straps, do so with just the straps. Leave the ratchet cams out. Its still not ideal, but it works in a pinch for light duty pulls.
    wi_taco likes this.
  4. May 21, 2021 at 5:30 AM
    dfertig84
    ok good that makes me feel a little better and thanks for tips about what to do if it happens again. I'll use reverse and neutral.
  5. May 21, 2021 at 5:35 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Actuators get sticky if vent hose isn't connected. I would check Tcase fluid level while down there.
    Probably Ok but it doesn't hurt to perform maintenance.
  6. May 21, 2021 at 5:57 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Backup with the steering straight then go forward that's pretty normal on a hard surface.
  7. May 21, 2021 at 5:59 AM
    dfertig84
    The truck is at 36.5k miles and I changed the gear oil in the transfer case + rear/front diff at 33k.
  8. May 21, 2021 at 6:26 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I had a similar incident with my 05 Tacoma I was pulling some bushes out with my winch and one was a little stuck so I put it in reverse while winching and the same thing happened with my light it kept flashing I shut it off turned it back on and it went to normal but when you put a lot of pressure on the actuators sometimes they do get stuck
    With lots of pressure
  9. May 21, 2021 at 7:28 AM
    dfertig84
    ok thanks, as long as I didn't do any serious damage to my precious I'll be fine. Makes me feel better that this sounds like a somewhat normal thing and my truck is ok.
  10. May 21, 2021 at 7:35 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Even if l don't need 4wd, If I'm on a straight dirt road I'll take my foot off the gas and switch it into 4wd. I'll drive for a few minutes in 4wd then switch it back to 2wd. I'll do this a few times just to let the system work.
    I found that letting off the gas while it switches, lessens the clunking considerably.
    winkel likes this.
