Should I buy a 2002 4cyl with 160k?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaman1778, Aug 14, 2010.
  1. Aug 14, 2010 at 10:53 PM
    Tacomaman1778
    Tacomaman1778 [OP] New Member
    Jake
    Socal
    Been on this website trying to do research before buying, just wondering what your guys advice is on buying a 2002 4cyl prerunner 3 inch lift with 160k miles. It got a new engine 20k ago. My only real worry is the tranny anything else I should think about before buying? Is it not worth the risk of a bad tranny?. All advice helps thanks guys.
  2. Aug 14, 2010 at 10:55 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    i BOUGHT MINE V6 WITH 183 NOW 194...ITS STRONGER THEN EVAA
  3. Aug 14, 2010 at 10:59 PM
    Tacomaman1778
    Jake
    Socal
    What repairs had to be done/ what was done before you got it
  4. Aug 14, 2010 at 11:01 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    Nothing....just oil change
  5. Aug 14, 2010 at 11:05 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Getting a new engine at only 140k would make me wonder how it's been maintained through its life, unless I knew exactly why it was swapped (freak mishap or damage somehow unrelated to a crash or maintenance).
  6. Aug 14, 2010 at 11:07 PM
    Tacomaman1778
    Jake
    Socal
    He did a compression test and found out he had two bad head gaskets so instead of just replacing the top he replaced the whole motor.
  7. Aug 14, 2010 at 11:07 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    true....why was it changed?
  8. Aug 14, 2010 at 11:30 PM
    Tacomaman1778
    Jake
    Socal
  9. Aug 15, 2010 at 12:32 PM
    Barnone
    Barnone Guest
    How does the rest of the truck look and check out? Price should be adjusted for the miles. Know a trusted mechanic to check it out?
  10. Aug 15, 2010 at 2:04 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2018 WRX
    bought mine with 155,000
    no motor swaps yet
