Should I buy a 2007 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ThWind81, Jul 28, 2015.
  1. Jul 28, 2015 at 10:29 AM
    ThWind81
    ThWind81 [OP] New Member
    Dustin
    2007 Tacoma
    I am interested in a 2007 Tacoma 4x4 V6 at a nearby dealership. I started doing research and found terrifying information on frame rust. I live in NW Indiana so there is salt in the winter. Who owns a 2007 or similar Tacoma and what has your experience been with frame rust? Engine mounts?
    Thanks!
  2. Jul 28, 2015 at 10:32 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    I mean, every truck is a little different depending on how they were maintained. If you are curious just crawl up under there and take a look. If it is rusty you will figure it out pretty quick. Also, bring a tiny hammer or something and tap along the frame rails to see if there is any.
  3. Jul 28, 2015 at 10:51 AM
    ThWind81
    Dustin
    2007 Tacoma
    Thank you for the reply. I plan on tapping around under there with my flashlight. I was just wondering if anyone has had problems or experience with the rust or having the rust fix applied and how well that works etc... I thought maybe the forum could give me a better feel for how likely I would be to run into this problem.
  4. Jul 28, 2015 at 12:23 PM
    ChiefManyWrenches
    Florida
    Yeah, I live in North Central Florida so I will not be much help here.
  5. Jul 28, 2015 at 12:54 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  6. Jul 28, 2015 at 1:03 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Any used car is going to have some flaws, so that said it is a good idea to check around. The frame rust issue seems to occur in three different stages. Light surface rust, medium-heavy surface rust, and hollowed out frame rust. The best way to tell how the truck was maintained is by simply looking underneath it. If the truck looks clean and up to your standards, I'd say buy it. If you're concerned that the frame is going to rust on you with the salty roads, have the truck under coated with some bed liner or oil annually. Any vehicle is going to rust in salty conditions if exposed over long periods of time.
  7. Jul 28, 2015 at 1:31 PM
    ThWind81
    Dustin
    2007 Tacoma
    Thank you guys for the awesome info. Chopper, great to know that those are the good engine mounts and that it slipped the newer electrical system. Gsxr, thank you for the heads up on the recalls and it is a 6 spd manual, how costly is the TOB issue?. Zach, I plan on doing something like a bedliner undercoat if I get this thing. The dealer is asking $17,800 for it with 96,000 miles but I can definitely get them down a couple thousand dollars on it as I also work with the dealership from time to time. I am getting rid of my 2007 Hyundai Accent also. Possible trade-in.
    Thanks again!
    ZachPrerunner likes this.
  8. Jul 28, 2015 at 2:27 PM
    HvH
    HvH Member
    Damon
    2007 silver Tacoma
    Not sure about the price they're asking but I've had no problems with mine and I've got 83G miles on it. Taking in just now to get new leaf springs and shocks and struts. Figure 83G miles I'm sort of due for new ones.
  9. Jul 28, 2015 at 3:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    Whatever you buy, paying for a mechanical pre purchase inspection from an independent shop you trust will be worth every dime you spend.
    You'll either buy with confidence, avoid problems that would have been many more times the inspection cost, or find modest, but fixable problems to use to your advantage to negotiate a better price with.
    The underpinnings should be part of the inspection on any vehicle, particularly northern and coastal ones.
  10. Jul 28, 2015 at 4:01 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    $18K for an 8 year old truck is high IMHO.
    ... of course, those are dealer prices. They probably bought it from the previous owner for $12/14 K. :)
