Should I buy this truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SAB_0010, Dec 12, 2016.
  1. Dec 12, 2016 at 5:54 PM
    SAB_0010
    SAB_0010 [OP] Well-Known Member
    Seth
    1996 Tacoma 3.4l 5-speed
    I found a listing on the local craigslist today and I need some opinions from other Tacoma owners. My 1996 has 284k and I've been keeping an eye for one with lower miles. Here is the listing.
    https://hickory.craigslist.org/cto/5916910569.html
    It looks a little rougher than my truck but it has 100k less miles. If any of you are from NC don't buy it out from under me if it's a good price haha.
    DustStorm4x4 likes this.
  2. Dec 12, 2016 at 6:06 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    What are your plans for a new truck? Daily driving? Dedicated off-road toy?
  3. Dec 12, 2016 at 6:09 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Hows the frame? (rust wise)
  4. Dec 12, 2016 at 6:11 PM
    SAB_0010
    Seth
    Semi-daily driver. I typically drive my civic to save on gas. Do you see any big dents other than the tailgate? My eyes aren't the best haha. If he still has it this weekend I am going to go look at it.
  5. Dec 12, 2016 at 6:12 PM
    SAB_0010
    Seth
    Says it doesn't have rust but I haven't gotten under it and looked yet
  6. Dec 12, 2016 at 6:16 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I see a little door ding above the front driver side tire, but other than that and the tailgate, I can't really find anymore. But the pictures aren't all that clear.
    IMO it looks a little rough, and I can kinda see it needing work to be done to it. Idk if you wanna spend more money on repairs or more money on a truck that doesn't need them. That's up to you.
  7. Dec 12, 2016 at 6:22 PM
    SAB_0010
    Seth
    I would probably replace the tailgate and I have the decals to put back on it. I don't know how bad the paint is so that may look even worse. I'm more concerned with how it runs and what it needs and if it has been taken care of. That's not easy to tell until I look at it and even then you never know.
    DustStorm4x4[QUOTED] likes this.
  8. Dec 12, 2016 at 7:36 PM
    kylehirsch87
    kylehirsch87 Member
    Kyle
    99 tacoma ext cab TRD
    Supercharged, cold air intake
    Looks like its gonna need all new suspension. Its sitting a little low to me.
  9. Dec 12, 2016 at 8:45 PM
    maulcruiser
    maulcruiser Well-Known Member
    Wilmington, NC
    96 Tacoma Xtra Cab 3.4L 5-speed
    OME kit
    Crawl all under that truck. Western NC loves to use brine on the roads during the winter.
    Markcal likes this.
  10. Dec 12, 2016 at 8:55 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    Is it me, or does the hood and rear bumper looks damaged also?
  11. Dec 12, 2016 at 9:23 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Is the anything wrong with your current truck other then it having higher miles? If it's in good shape and has been maintained I would look more in the direction of replacing/rebuilding components (engine, trans) when they go bad.
    Then you keep the truck you already know and trust.
  12. Dec 13, 2016 at 3:07 AM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    I would check on the frame rust in the notorious areas and the last timing belt/water pump replacement. If that is due it will be around 700 to have a shop do that. Check all suspensions components, bushings, joints, cv axles and negotiate from there.
    Obsessed2000 likes this.
  13. Dec 13, 2016 at 3:47 AM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    She looks like she's got a bunch of dings, and hard to make a sound decision without seeing the interior.
    Also doesn't have a plate on it and looks to be sitting in a "farm" like setting. So that means she's either been sitting for awhile to let the plate lapse, it may be a dedicated farm truck, or somebody just flipping it. Either way I think its throwing up some red flags and I'd probably pass unless you talk him down to something like 3k.
  14. Dec 13, 2016 at 1:00 PM
    SAB_0010
    Seth
    Yeah, my truck is due for coilovers and shocks too
  15. Dec 13, 2016 at 1:02 PM
    SAB_0010
    Seth
    I know, I am from the Hickory area. I wish they would just leave the roads alone, the refreeze makes it worse anyway
  16. Dec 13, 2016 at 1:04 PM
    SAB_0010
    Seth
    I can't tell. I might go see it tomorrow evening if I have time
  17. Dec 13, 2016 at 1:07 PM
    SAB_0010
    Seth
    It's pretty clean, just has a few problems. Suspension is shot, it's in need of a rebuild, needs timing belt, and a steering rack couldn't hurt anything. I would rather sell it and get one with fewer miles before it gets past 300k and I won't be able to get much out of it.
  18. Dec 13, 2016 at 1:09 PM
    SAB_0010
    Seth
    Where are supposed to be the worst places on the frame? I'm sure it is in need of a timing belt but I can do that myself and save a couple hundred on labor.
  19. Dec 13, 2016 at 1:13 PM
    SAB_0010
    Seth
    Yeah it looks like a work truck so I'm a little worried it hasn't been taken care of. If its got a bunch of dents on the body other than the tailgate and if the interior is bad I'm not going to get it. The guy sounded a little sketchy too so who knows what kind of shape it is in.
  20. Dec 13, 2016 at 2:14 PM
    UtahTacoma02
    Dave
    SLC
    Check the bottom section all along the long straight part of the frame and also the curved part of the frame where the rear leaf spring mounts are attached to the frame. That section seems to be the first to go which is why the Tacomas are broke in half on a google search for "Tacoma frame rust." The frames rot from the inside out.
