should I buy used R150
Discussion in '1st Gen. Tacomas (1995-2004)' started by edbranch, May 9, 2025.
  1. May 9, 2025 at 9:09 AM
    edbranch
    edbranch [OP] Active Member
    ed
    1999 Tacoma xtra cab 3.4 2 wh drive man
    Found one nearby from a private seller. 155K. Seller says it's in good condition but provided no details. I realize this is a crapshoot as I need to pay someone install. Considering it because we've got unexpected house repairs now. Guessing there is no way to tell if it's good or bad. Opinions?
  2. May 9, 2025 at 4:33 PM
    Cucvfan
    Cucvfan Well-Known Member
    What is the price of buying the used trans & paying a shop to install it versus having the shop rebuild yours?
    StreetTaco95 likes this.
  3. May 9, 2025 at 5:08 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    A rebuild (good one) would be expensive, in many cases. Running in through the gears and turning it by hand can tell a lot. The X factor is that you need to pay for installation, so I guess it depends on the cost of the trans and the labor. I would probably risk it but I would also be doing the labor. How much for the trans?
    StreetTaco95 and barnaby like this.
  4. May 10, 2025 at 6:43 AM
    edbranch
    ed
    Thanks for replying. $400 for used transmission. $1400 for rebuild. $800 for installation.Plus the clutch. Hate to be cynical but there's no way to really know if the reported mileage of used transmission is accurate.
    MadNachos[QUOTED] likes this.
  5. May 10, 2025 at 11:54 AM
    MadNachos
    If possible I would drain the used transmission oil through a paint strainer and look for metal, no metal, probably OK.
