Should I cange LR UCA setting?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sfcadams, Jan 13, 2013.
  1. Jan 13, 2013 at 11:25 AM
    sfcadams
    sfcadams [OP] Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Recently went back down to 265/75/16 tires from 285/75/16 tires. I have the LR UCA set at the +2.0 setting (with the logo facing the wheel). Should I change the setting on it to the 0.0 setting now that I have dropped down in tire size before I go get an alignment? I am running the Maxtrac spindles if anyone thinks that information is needed to make this decision.
    Thanks in advance
    EDIT : Just realized I typed cange instead of change
  2. Jan 13, 2013 at 11:30 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Tire size will change the handling a little but it doesn't change your main alignment angles. I'd leave it be.
  3. Jan 13, 2013 at 11:32 AM
    sfcadams
    Dan
    Elizabeth, Indiana
    I was thinking that they may not be able to get the alignment within specs for my truck with the UCA set at +2.0 and with me changing the tire size to a smaller tire.
  4. Jan 13, 2013 at 11:34 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Tire size doesn't effect alignment angles. Should be fine.
  5. Jan 13, 2013 at 11:37 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Why are you set at +2 and not at 0?
  6. Jan 13, 2013 at 11:43 AM
    sfcadams
    Dan
    Elizabeth, Indiana
    I set it at +2 before I installed my 285/75/16 tires to allow the alignment shop to try and get the alignment within specs. With it set at +2, it allows caster adjustment from 0.0 to +4.0, or at least that is what I read.....
    With me having the Maxtrac spindles, all of my front end geometry should be back like it would be as stock, correct?
    This is why I was asking if I should set the UCAs at 0.0 since my front end is theoretically back to stock with my Maxtrac spindles....?
  7. Jan 13, 2013 at 2:03 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    Any other opinions out there?
  8. Jan 13, 2013 at 2:09 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    ^^ this. we can all chime in and say this all day. changing tire size does not affect alignment.
  9. Jan 13, 2013 at 2:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  10. Jan 13, 2013 at 4:17 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    ya I didnt get a new alignment when I put my smaller winters on and its fine.
  11. Jan 13, 2013 at 4:18 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    changes in the suspension geometry and whatnot require alignments afterwards, tire swaps don't
  12. Jan 13, 2013 at 4:22 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    This. Typically guys with ~3" lifts have the UCAs set to +2 to make up for the lost caster when adding longer springs. I guess i am not very familiar with spindle lifts, but i have read spindle lifts don't screw up your alignment like a 3" coilover lift. So I'm thinking you should be able to set the UCAs at 0 and still be in spec. Doesn't matter though if your alignment is already good, just thinking out loud and looking for some answers.
  13. Jan 13, 2013 at 4:24 PM
    Mitch
    Mitch
    Spokane, WA
    Wait a minute. So should I change my LR's to +2 from 0 with my Icon set up? I'm around 2-2.5" in the front.
  14. Jan 13, 2013 at 4:30 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    The neutral setting with the spc logo facing the tire adds +2 caster
    After i lifted 2.5 inches i lost almost exatly 2* of caster, the nuetral setting (+2) got me 2.7*
    What i am wondering is do spindle lifts cause you to lose caster like coilover lifts
  15. Jan 13, 2013 at 4:39 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I did, pulls the wheel forward and lets you add caster to bring them to the spec the should be, about 2.5-3
  16. Jan 13, 2013 at 5:58 PM
    OZ-T
    Peter North
    British Columbia
    Neutral , SPC logo facing out ( +2 caster ) put me at about 2.7 caster before we messed with the cams with my 2 1/2" , OME 885 lift
  17. Jan 13, 2013 at 5:59 PM
    OZ-T
    Peter North
    British Columbia
    Most alignment places don't deal with adjustable UCA's
  18. Jan 13, 2013 at 6:02 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Only if the mechanic knows how to adjust the LR UCA's. Most guys here set them at +2* themselves, and then the mechanic will mess with the LCA's and tierods.
  19. Jan 13, 2013 at 6:09 PM
    Mitch
    Mitch
    Spokane, WA
    Plus you are going to have to lift the truck, pull the tire off and possibly disconnect (if I remember correctly) the spindle
  20. Jan 13, 2013 at 6:10 PM
    Mitch
    Mitch
    Spokane, WA
    Good to know thanks. I have minds set with the Logo facing out. Forgot where that placed the caster
