Should I change my rear diff fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JayARRGHH, Mar 19, 2011.
  1. Mar 19, 2011 at 8:31 PM
    JayARRGHH
    JayARRGHH [OP] Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
  2. Mar 19, 2011 at 11:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Water can get sucked into the diff when the diff cools from being submerged. In my opinion, you did not spend enough time in the the water for cooling to be a factor.
  3. Mar 19, 2011 at 11:22 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Not necessary
  4. Mar 20, 2011 at 8:23 AM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    X2
  5. Mar 20, 2011 at 5:36 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    alright, whew! thanks guys. I did a few more runs through though, but that makes sense what you said so I don't think it was enough time in to cool at all. Thanks again!
  6. Mar 20, 2011 at 5:39 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I've been through more mud and water than that x100. I have not once changed it. Never had a problem, never did breather mod.
  7. Mar 20, 2011 at 10:24 PM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Not necessary x3.
    My uncle NEVER changed his rear diff fluid at 140k miles with tons of deep water crossings and even got suck in deep water. If his rear diff is fine then you shouldn't worry.
  8. Mar 20, 2011 at 10:31 PM
    ColtsTRD
    Scott
    AZ
    I definitely wouldn't recommend going that long without changing the fluid...the plug acts as a magnet as well and catches any small metal shards that may wear off the gears over time. Over time the plugs magnet gets full of shards and it won't catch extra metal floating around. I changed mine at 70K miles using Mobile 1 Full Synthetic. If you do change the fluid just pick up a new plug from Toyota, I think there 5 or 6 bucks
  9. Mar 20, 2011 at 10:36 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    x4
  10. Mar 20, 2011 at 10:44 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    good advice, thanks man.
  11. Mar 20, 2011 at 11:01 PM
    ColtsTRD
    Scott
    AZ
    your welcome :cool:
