Should i change out my shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by ffr3064k, Sep 2, 2010.
  1. Sep 2, 2010 at 6:44 PM
    ffr3064k
    ffr3064k [OP] Active Member
    Castle Rock, CO
    03 Double Cab debadged
    3 Inch lift, 32 x 11.50 Mudders, DVD, Headrest Monitors, Navigation, Sirius Radio, Subwoofers, Complete Color Change
    I currently have the following set up on my 2003 4 wheel drive double cab.
    Running Cooper STT 32 X 11.50 Tires, Bilstein 5100's set to 0 with Eibach 3 inch lift springs on the front. The rear is setup with OME Dakar 2.25 inch lift leaf packs and Skyjacker shocks. The problem is that it is very bouncy (mainly notice it on cement roads) I have been thinking of scrapping the Skyjacker shocks for Bilstein 5125's to try and improve the ride. I am happy with the setup for increased travel, flex, and offroading. I would just like to improve the feel on the open road if possible. I have also considered adding weight in the bed to try and reduce the bounce. I know many of you have a very similar setup on your trucks. What do you think?
  2. Sep 3, 2010 at 10:35 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    When does the bounce occur on the road, is it when you hit big bumps or small bumps?
    Is it a consistent bounce, if so your tiers may need to be rotated and balanced.
    If it occurs when you hit small bumps it could be your shocks are too stiff, and the billys will fix that they are more of a spongy ride.
    If it occurs when you hit big bumps your shocks are probably worn out.
  3. Sep 3, 2010 at 8:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I have a similar problem when the bed is empty it seems a bit bouncy. I know I can add sand bags and it'll ride smooth but I'm wondering if replacing the rear shocks with a slightly longer set will help.
    Currently running KYBs with Alcan 8s. The KBYs are for extended length of 2" over stock. The Alcans gave about 2.25" of lift. On The trail this combo is great. On the street it's a bit bouncy.
  4. Sep 3, 2010 at 9:07 PM
    ffr3064k
    Castle Rock, CO
    I knew the shocks were not worn out as they were only 3 months old and the tires were balanced recently and they were rotated yesterday. Still, had the constant bounce over small bumps. Almost could feel every crack in the road. I added weight in the bed this morning and still felt little difference.
    As a result, I changed out the rear skyjacker shocks for the Bilsteins. What a incredible turn around. The ride is much smoother now. With my setup it is still stiff but flexible with great articulation for offroad and is very comfortable on the highway and around town as well.
    The set up again is Bilstein 5100's set to zero with Eibach 3 inch lift coil springs in the front. On the back I have OME Dakar 2.25 inch lift leaf springs with Bilstein 5100 rear shocks. Total cost for the suspension setup was 850.00. For tires I am running Cooper STT mud terrain 32 x 11.50 15 inch tires. I highly recommend this setup and learn from me..don't waste your money on blocks, spacers, and cheap shocks.
  5. Sep 3, 2010 at 9:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Did yo go with 5100s or 5125s as you posted earlier?
  6. Sep 3, 2010 at 9:51 PM
    ffr3064k
    Castle Rock, CO
    Toytec gave me 5100's. I believe the part number was BE5-D560-T0. Downsouth motorsports also showed the same part number online in the complete Bilstein package.
  7. Sep 3, 2010 at 10:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think you had already gone from skyjackers to 5100s even before you wrote that you were considering 5125's
  8. Sep 3, 2010 at 10:33 PM
    ffr3064k
    Castle Rock, CO
    Wrong. 5100's on the rear were bought and installed today from Toytec. The 5125 post was done lastnight. Toytec is a 20 minute drive for me.
  9. Sep 4, 2010 at 6:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That's cool. Thanks for clarifying.
