Should i close off elbow with deckplate mod?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98fourbangertaco, Aug 15, 2010.
  1. Aug 15, 2010 at 10:49 AM
    98fourbangertaco
    98fourbangertaco [OP] Well-Known Member
    Taylorsville, NC
    98 toyota tacoma, 4wd, SR5, 2.7L, 5-speed
    daystar 2.5in suspension lift kit, detroit truetrac in rear, custom transfer case skidplate, deckplate mod, green high-performance drop in filter, Huskyliner floor mats, 31x10.50 wild country radial mtx tires, yakima roof rack, load warrior basket, stubbs welding rock sliders, arb front bumper with warn 9,000lb winch and procomp black series 100w offroad lights, trail-gear rear bumper, borla exhaust, blacked out factory wheels, shovel mounted on roof rack, de-mudflaped
    I done the deckplate mod to my 2.7 a couple monts ago, I was thinkin I might should close off the elbow so all of the air comes in through the deckplate but most all of the air proably comes in through the deckplate anyway because it is forced, any opinions
  2. Aug 15, 2010 at 11:02 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I don't think you need to shut off airflow from the original , unless its making your truck run lean...
  3. Aug 15, 2010 at 11:06 AM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    i wouldnt. its cooler air than what comes in through the deck plate
  4. Aug 15, 2010 at 11:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Air will take the path of least resistance....which will be the hole from the deckplate.
  5. Aug 15, 2010 at 12:17 PM
    Barnone
    Barnone Guest
    It appears that the intake air temperature is less since I've done the deck plate mod according to my SGII and I am moving.
    Hard to say for sure.
    I did not remove the elbow since I might have a reason to put the deck plate in.
  6. Aug 15, 2010 at 6:11 PM
    98fourbangertaco
    Taylorsville, NC
    Thanks guys, thats what i thought janster, i figured 99% of the air would be forced through the deckplate anyways and i wouldnt matter what you did with the deckplate
  7. Jun 6, 2015 at 7:46 AM
    heyjones
    heyjones Member
    Fullerton, CA
    I'm in the same boat, considering chopping the elbow instead of plugging it, though. That mod is similar to the deckplate install but doesn't increase airflow as much.
