Should I ditch my K&N?
Discussion in '4 Cylinder' started by Trialsdork, Nov 21, 2014.
  1. Nov 21, 2014 at 11:14 AM
    Trialsdork
    Trialsdork [OP] Member
    Joe
    '10 SC 4x4
    I just bought a '10 2.7 that came with a K&N and my buddy who owns a salvage yard advised me to go back to stock. I should at least clean the MAF and Throttle body, but I don't like the idea of the grit getting in that motor! He's a pretty smart guy, but I'd like to get the opinion of yous guys! How hard is maintenance on a K&N? What do I need?
  2. Nov 21, 2014 at 11:16 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    yep too oily, get rid of it and clean the MAF and you will be good
  3. Nov 21, 2014 at 11:38 AM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Go back to stock. If you have a hard time finding a stock intake at least get a dry filter like an AFE.
  4. Nov 21, 2014 at 11:40 AM
    Aw9d
    Aw9d That one guy
    I've ran K&N and other oiled filters since the day I got a car. Never once had issues with too much oil, because I don't over oil it.
    If you follow the directions right they won't do damage. People who have had issues over oiled it, clogged their MAF and now blame the product for their mistake.
    If you don't want to deal with oil, AFE dry filter is the way to go.
  5. Nov 21, 2014 at 12:12 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    same here, never once had a problem running k&n. Paper filters will filter a bit better though.
  6. Nov 21, 2014 at 12:32 PM
    Flowin
    Acworth, Georgia
    I had problems after 10k running it in my STI, it came stock out of the box and I never oiled it (maybe it was just not my lucky day)
  7. Nov 21, 2014 at 1:08 PM
    Trialsdork
    Joe
    '10 SC 4x4
    Luckily, my state does nothing of the sort. You can drive ATV's on public roads here. Basically, if you can bolt a license plate to it, you can drive it on public roads. So I will just clean and maintain mine unless I see a crazy deal on a stock setup on ebay or something. Lots of dusty gravel roads here.
  8. Nov 21, 2014 at 1:09 PM
    Trialsdork
    Joe
    '10 SC 4x4
    Thanks for the help, lads.
  9. Nov 22, 2014 at 9:08 PM
    vern650
    brandon
    hyrum, ut
    my tacos had one on for that long and no issues, but I won't run k&n on my duramax. They let to much dirt through for turbo/boosted applications imo, however I am running a diesel specific oiled cotton type filter which is pretty much the same but has twice the number of layers to filter out finer particles. Its been on for about 5 years and zero issues.
  10. Nov 23, 2014 at 3:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    There are a lot of K&N haters here...
    I've owned a couple different K&N's over the years. If you keep them cleaned, don't over-oil them, and they're seated properly...you shouldn't have any problems. I never had problems in the 5 years I had one in my 96.
    I cleaned it twice a year - regardless of how clean it looked.
  11. Nov 23, 2014 at 4:01 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    poor filtering, toss it
  12. Nov 23, 2014 at 6:39 AM
    wdb
    Dave
    the perimeter
    plain jane
    Not a hater, I just don't see the point of them. I guess maybe if you want to hear intake noise, which I don't.
  13. Nov 23, 2014 at 7:14 AM
    TacomaRobert
    TacomaRobert Well-Known Member
    What the heck is wrong with a high quality paper filter? ?? Been using them since day one without a problem.
    The only times i hear about a problem is with the oil filters.
  14. Nov 23, 2014 at 7:50 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Just get a dry filter from AEM who's now owned by K&N......just have to look up size.
  15. Nov 23, 2014 at 8:48 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Paper. I had a K&N on my '95 Runner. It wasn't worth the hassle. Messy, dirty, the wire mesh started to fray, and I really didn't notice a heck of a lot better performance or mileage. I just run a quality paper and change it more often than factory reccomendation.
  16. Nov 25, 2014 at 11:11 AM
    RdRunr
    RdRunr Well-Known Member
    Dan
    still in the Matrix
    2014 Base, white, reg cab, 2.7L, 5-spd
    DT header, Flowmaster 50 Series Delta Flow muffler
    I had heard the same. Someone tested K&N vs. paper. Paper did a better job at filtering. Not lots better, but measurably better. I'm going to be putting lots of miles on my little Taco, I want the best filtering I can get so I'm staying with paper. If you are racing and care only about airflow, go with K&N.
  17. Nov 26, 2014 at 1:29 PM
    TacomaRobert
    Excellent point. I'm with you.
    When I need to drive only 1,000 miles and then tear down my engine, they will be at the top of my list.
  18. Nov 26, 2014 at 8:35 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    That is not true, only Californistan has the F'd up CARB labeling requirements and it has nothing to do with actual "smog " inspection. In CA the visual inspection is where it will hit you if the product is not CARB certified and currently only Airaid and the TRD intakes are CARB. Technically a shit load of aftermarket intake and exhaust products will pass smog sniff testing without any problem at all but CA as of January 2014 no longer smog sniffs it is now an ODBII reading and visual inspection only. It is a fkn scam to get companies to pay the state hundreds of thousands of dollars to get their product CARB certified.
