Should I do a tune up?
Discussion in '4 Cylinder' started by norcal4banger, Mar 31, 2011.
  1. Mar 31, 2011 at 9:00 PM
    norcal4banger
    norcal4banger [OP] 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    I have a 120k miles. Should I take it in for a tune up? Hasn't had one yet.
    Also, I was already planning on replacing the spark plugs. I'm assuming they're fine still because I haven't looked at them but at 120k I figure why not. So what kind of spark plugs should I get?
  2. Mar 31, 2011 at 9:11 PM
    norcal4banger
    Jack
    I guess no?:)
  3. Mar 31, 2011 at 9:24 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    not sure what plugs the 4 cyl has but the best plugs have a expected life of 100k, so id go ahead and buy some factory replacement plugs.
  4. Mar 31, 2011 at 10:09 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    There's not much to tune up on these engines. Spark plugs are spec'd for 100k. I went with OEM denso plugs. Coolant is also spec'd at 100k. Again I went with the Toyota coolant like the manual says. Fuel filter is in the tank and supposedly lifetime so I didn't replace that yet. Replaced the serpentine belt not too long ago so it didn't need it at 100k. Check brake pads/rotors and adjust the rear drums. Clean/change your air filter and change your oil/filter and you're pretty much set.
  5. Apr 1, 2011 at 3:23 AM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    I know my 08 says to replace the plugs, even under severe service, the first time at 120K.
    Change em out.
    Do it yourself.
    Clean your throttle and intake to.
  6. Apr 1, 2011 at 7:21 AM
    JVannett
    JVannett Member
    Fargo, ND
    1996Tacoma Reg 2.7 4WD
    31" Tires 31x10.5 15"
    if you have the 2.7 like in mine the fuel filter is located under the intake manafold. i had to take mine off to replace it.
  7. Apr 1, 2011 at 7:37 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Mid-Atlantic
    '06 RC, 4X4, 5 speed
    Unfortunately on 2nd gens, they're located in the tank. Same way with my wife's Honda Fit. Sucks cause it's one of the first places I'd look if fueling issues were a concern.
  8. Apr 2, 2011 at 5:48 PM
    frog13
    frog13 Well-Known Member
    Are you sure it's the filter in the tank and not the pump?.
  9. Sep 22, 2014 at 11:37 AM
    Bogeyman
    Bogeyman New Member
    Fort Worth, TX
    05 PreRunner
    Changed my plugs at 190K. They needed changing but truck was still starting and running fine before I did it. I went with Autolite Double Platinum fine pin. I can tell a difference in the amount of gas I have to give to accelerate and maintain cruising speeds. Easy to do yourself, about a 2 hour job. Change my oil every 10K, always have. Use Royal Purple 5-30. And yes, fuel filter is in the tank on 2nd gen tacos.
    HA, just noticed how old this thread is. Oh well....
