"SHOULD" I do the TSB, Help with Decision?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Aug 2, 2011.
  1. Aug 2, 2011 at 1:11 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    For my 2011 DCSB.
    I have loaded maybe about 600lbs, very rough estimate, of camping gear and two bikes on a hitch rack. The leaf springs were about 1 1/4 from the bump stop when not moving. On the road I didn't feel it bottom though, amazingly. I thought for sure it would hit the stops.
    I might carry a load like this 2-4/yr, maybe more weight if I'm hauling dirt or landscape materials. Mostly the bed is not loaded for my driving. I don't have a shell or any heavy bumpers. I will be putting skids on soon, and a slight chance that I'll put on sliders in the future. I may put a shell on later as well. I'll be leaving stock bumpers on. I'm estimating the Bud Built mid and t-case skids weigh about 150lbs total.
    I am needing help with the decision to put on the TSB leafs or not. I plan to lift it soon and am not sure if I should go with the TSB AAL, non-TSB AAL, or a new leaf pack. I'm deciding between OME at 2.5-3 or adjustable Bilsteins 2.5-3.
    I'd like a smooth as possible ride, or at least close to stock as possible.
  2. Aug 2, 2011 at 1:17 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    I say why not, I would do it. I did notice a stiffer feel in the back after the TSB but that's to be expected and it doesn't bother me.
    I put right around 1300lbs in the back of my truck this weekend (with TSB) and was still 1 1/2-2" off of the bump stops. I only went 10 miles round trip with it but I did not hit the stops at all.
    Previously like you I was very close to the stops at 800ish lbs ..
  3. Aug 2, 2011 at 1:18 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    If a new leaf pack is within your means, wait until you lift and swap it out. It'll yield the best results by far. It sounds like you don't need the TSB pack if you can put that kind of weight in the bed and not bottom out. I was hitting the bump stops hard with much less weight before I got the TSB.
  4. Aug 2, 2011 at 1:21 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    If you want as smooth as ride comparable to the 3 leaf OEM then wait and get a complete leaf pack when you're ready to lift your truck.
  5. Aug 2, 2011 at 4:11 PM
    tacomtn
    Hmm, a replacement leat pack would provide a better ride AND give a higher spring rate to reduce the rear squat when loaded?
  6. Aug 2, 2011 at 6:36 PM
    Pugga
    Massachusetts
    Depending on which leaf pack you buy, yes!
  7. Aug 2, 2011 at 6:38 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Dakars
  8. Aug 2, 2011 at 9:14 PM
    tacomtn
    Hey, OZ.
    Yeah, I was thinking of Dakars. I noticed in your build you're running 265/70R17s. Any problems with rubbing? What wheel, offset, and backspacing? How much did the Dakars lift the rear? How is the ride compared to stock?
  9. Aug 2, 2011 at 10:47 PM
    OZ-T
    Peter North
    British Columbia
    No rub
    Stock wheels
    2 3/4" lift
    Rides nice with my cap on , a bit stiff without
    I like
  10. Aug 3, 2011 at 6:21 AM
    coop1212
    coop1212 Well-Known Member
    ms
    2010 TRD 4x4 double cab offroad
    none yet!
    Going to watch this thread! In same boat with my 2010
  11. Aug 4, 2011 at 7:19 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I would get the TSB done if your under warranty and its available to you, since it is an upgrade to the truck for free. I do not feel it is stiff with the TSB or 4 leaf spring replacement, and I drive with the bed empty most of the time. It just gives the truck a firmer, or more of a solid feel. And, when you use the truck to haul or tow it handles the load better then the stock springs. Sure, there are better spring sets out there that may be ideal for specific applications, but for the stock truck this is a nice freebie IMO...:D
  12. Aug 4, 2011 at 7:30 PM
    coop1212
    ms
    none yet!
    i took mine into the dealer today. im setup for tuesday morning!
