Should I enjoy my new Tacoma stock before I mod?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zCheech, Apr 13, 2021.
  1. Apr 23, 2021 at 4:48 PM
    #61
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
  2. Apr 23, 2021 at 4:50 PM
    #62
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Chrome must go. Toyota should be jailed for criminally poor taste.
    Now I'm forced to deal with chrome vent rings until Meso restocks them in black.
    I'd rather be blind than look at that --although with all the glare I should be careful what I wish for...
    zCheech[OP] and danmtchl like this.
  3. Apr 23, 2021 at 4:57 PM
    #63
    Waynebarkr
    Waynebarkr Well-Known Member
    Wayne
    Phoenix
    2020 Cement DCLB TRD-OR AT
    I agree about the roof racks. When you find out that they can actually carry very little weight (look at Ronny Dahl on youtube and the issues he had with roof racks) and the hit you get with your MPG you realize that they are mainly for looks. If you want to sacrifice mileage for looks that is your choice.
    Personally I would go for the OEM roof rack since they are rated at about 75 to 100 lbs carrying capacity--which seems to also be the SAFE carrying capacity of the ROOF--so if you put a different rack on the ROOF, even if the rack can carry more (which almost ALL of them say they can), the ROOF cannot SAFELY carry more. I know people do it all the time but doesn't seem to be a safe practice,
    danmtchl likes this.
  4. Apr 23, 2021 at 5:39 PM
    #64
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    ^^^this. But also a stock bed mat, dashcam, and put tailgate protection on it (like a SaBellCo lock and cable eye cover washers- but don’t depend on the hoseclamp trick, it is really useless because the clamps can be easily and quickly broken off)
  5. Apr 23, 2021 at 6:06 PM
    #65
    TX Bat
    TX Bat Enabler
    Keith
    North Texas
    2019 TRD Pro BLACK
    Welcome!
    You got the right idea. Do the "no brainers". They are usually inexpensive.
    Drive it and take it off road. You will be pleasantly surprised at how capable the truck is in the stock form.
    When you run into something that stock won't handle, in your experience, then you can consider what to upgrade.
    As a note, when you add mods, you will add weight. When you are satisfied with your mods, you can assess whether or not the stock suspension will be good. Upgrade the suspension for the final weight of your truck, not the initial weight. That might take a while, depending on your budget.
  6. Apr 24, 2021 at 8:13 AM
    #66
    DesertDuck2004
    DesertDuck2004 Well-Known Member
    AZ
    2020 TRD OR DCLB - MGM-KDMax'd
    I would do the following as soon as I drive it off the lot.....
    Bed Mat
    KDMax 6.0 tune
    Tires
    Anything else depends on use/lifestyle/personal preference
    danmtchl and boston23 like this.
  7. Apr 24, 2021 at 12:09 PM
    #67
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    The lift and tires are going to change your truck if you drive it three months or not. The most important thing here is can you afford the mods. If you can then you just have to do it and see. I drove mine ~12k before I did anything other than black out stuff and lights. Then I put everything on. Nothing could have prepared me for the new stuff but I'm tickled how it came out. Most decent mods for these trucks are really well done.
  8. Apr 24, 2021 at 12:34 PM
    #68
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Coming from a gen1 4wd tundra i thought that was pretty decent in the snow. This 2020 tacoma blows it away. Even in 2wd its very capable. Where my tundra got stuck and hung up, this tacoma just laughs at those spots.
  9. May 5, 2021 at 10:30 AM
    #69
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    I had 19,250 miles on my TRD OR when I put my Ironman Foam Cell suspension on. I got the rear springs for 450-800lbs, thinking with a clam shell RTT and half rack, plus adding in a homemade draw with stuff in them, Dometic 75 fridge/freezer and when off road a couple of fuel cans and a couple of water cans plus other stuff. After putting on the lift, I thought man did this get lifted more than 2" (front coil overs set in the middle), it did, I got 3.25" in front and 4.5" in back from my measurement before removing the old suspension. With about 450lbs in the back with the old suspension I was sagging about 3-3.5" and why I had such a big change. I didn't notice the rear was already sagging so much. I went to a dealership and measured a new TRD OR, in reference to the new truck I went up 2.5" in front and 3.5" in back with about 250lbs on the back.
    Keep it stock will depend on what you use it for. I have carried some wood in the back for projects, but this is not a work truck and shouldn't of sag the way it did.
  10. May 5, 2021 at 12:55 PM
    #70
    kowloontong
    kowloontong Member
    Wait and see what you like or dislike. One mod may not be as important as you thought - especially aesthetic only mods.
    zCheech[OP] likes this.
  11. May 5, 2021 at 1:59 PM
    #71
    Blasterjack
    Blasterjack Member
    Joe
    Mesquite Texas
    2019 Super White TRD Off Road 4x4 Long Bed
    Weather tech floor liners LED Interior lights LED Reverse light LED license plate lights AJT Design Red climate control rings AJT Design Red A/C vent ringS AJT Design Red key fob w black screws Red TACOMA Glove Box Letter Black tailgate letters Bed Mat
    Welcome to TW! And happy Cinco de Mayo! A lot of good information here, I have a 2019 DCLB with only minor upgrades.
  12. Jun 1, 2021 at 8:01 PM
    #72
    wilderness4wd
    wilderness4wd Well-Known Member
    Tennessee
    2021 Tacoma TRD Pro Super White
    [no mods yet]
    Do Prinsu cab racks make wind noise?
  13. Jun 1, 2021 at 8:04 PM
    #73
    ksimms92
    ksimms92 Well-Known Member
    Kevin
    West of Chicago
    2020 Silver TRD OR DCLB 4X4
    Buy one of each item from @MESO and you’ll enjoy it a hell of a lot more :spending:
    zCheech[OP] and MESO like this.
  14. Jun 1, 2021 at 8:12 PM
    #74
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2017 Tacoma TRD PRO
    If you paid cash...fuck yeah mod the shit out of it! The bank owns my 2021 so im not touching it for a few years :(
    zCheech[OP] and blocke like this.
  15. Jun 1, 2021 at 8:18 PM
    #75
    zCheech
    zCheech [OP] Active Member
    I have added a few mods and I have no regrets so far. Can’t wait to keep chadding it out.
    wilderness4wd likes this.
  16. Jun 1, 2021 at 8:22 PM
    #76
    wilderness4wd
    Tennessee
    [no mods yet]
    Does that rack have the light bar cutout or no?
    zCheech[QUOTED][OP] likes this.
  17. Jun 1, 2021 at 8:39 PM
    #77
    HoytK9
    HoytK9 Well-Known Member
    Voodoo Blue 2019 TRD Pro
    Snug Top Hi-Liner
    What others have already said! This is what I love about these forums, learning from the perspective of several other like minded folks with experience.
    I'll just go ahead and chime in a few of my thoughts:
    I would consider how long you tend to keep your vehicles. Wheels and tires are relatively inexpensive to swap out. Once you get into a lift, especially done properly, you are in it for thousands that you may only partially recoup if you were to ever sell your vehicle. You'll most likely be looking at larger, beefier wheel/tire combos. Many aftermarket bumpers that look the business and add real benefit will involve permanent mods to your vehicle (cutting). Your vehicle probably won't pass for the 'lightly used, never been off-road' variety when it comes time to sell.
    If you do intend to keep your truck, or for a lengthy amount of time, NEED vs WANT becomes a constant struggle.. at least it was for me. As others have suggested, take your truck out and learn how you intend to use it. If you have a buddy with a modded truck, go for a ride and see if it's for you. Write down your upgrades from essential to non-essential in a 'to-do' list.
    Most importantly, don't rush and ENJOY the process! And don't forget to share your experiences here with plenty of pics!
  18. Jun 1, 2021 at 8:55 PM
    #78
    cementnotgray
    cementnotgray Well-Known Member
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    Once you start you can't stop, it's worse than drugs.
  19. Jun 1, 2021 at 9:17 PM
    #79
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    CMC, UCA, and 3" lift in than less 2 months. 34's in 3 months. Added the pro grill in 5 months. Still under 2500 miles.
    Rides fine to me. Smooth and tracks straight. Seems slower but no big deal. Might get KDMax soon. Mpg sucks bad b/c 90% of my trips are less than 3 miles. Still get over a month on a tank. So NBD.
    Just do it as parts become available IMO.
  20. Jun 2, 2021 at 7:09 AM
    #80
    zCheech
    Yes it does.
    wilderness4wd[QUOTED] likes this.
