Should I extend my bumpstops with the OME Dakars
Discussion in 'Suspension' started by OZ-T, Aug 18, 2011.
  1. Aug 18, 2011 at 8:21 AM
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    As the title states , I have read conflicting opinions on how important it is to extend the bumpstops with the Dakars to keep the leaf pack from going into negative arch .
    Any clarification or opinions on how to best extend the stops if needed ?
    Thanks in advance
  2. Aug 18, 2011 at 8:23 AM
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    I used the timbren stops with mine and I have had no problems with my Dakars besides them rusting.
  3. Aug 18, 2011 at 8:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :popcorn:
    I'm curious for responses, I always thought extending the bump stops was so the axle hit the bump stops before the shock bottomed out. I didn't think negative arch was a concern but I guess I'll learn something today!
  4. Aug 18, 2011 at 8:41 AM
    okboatie1
    okboatie1 Well-Known Member
    Darrell
    Chula Vista, CA.
    03 PreRunner TRD SR5 DCSB
    OME 881's w/Dakar's, Deckplate mod, Debadged, door chime mod, 12V outlets always on,
  5. Aug 18, 2011 at 8:44 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    if you decide to do that, i dont know if you should or not. but i read another thread where someone suggested to cut 1/4 inch steel in squares to put under the bump stop to raise it off of the leafs. as long as ur u bolts are long enough. make sence?
  6. Aug 18, 2011 at 8:46 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    This^^^
    Dont.think bumpstops come into play until ur offroading or carrying heavy loads... Should only be on bumpstops then, but if ur carrying heavy loads alot ud want to ride on the bumstop to stop the springs from flattening/neg arch
  7. Aug 18, 2011 at 8:50 AM
    Pugga
    Massachusetts
    Wait, how the hell did you manage to bottom out the Dakars??? They have 2 overloads!
  8. Aug 18, 2011 at 8:52 AM
    97yota4wd
    Eric
    Mesa, AZ
  9. Aug 18, 2011 at 8:55 AM
    OZ-T
    Peter North
    British Columbia
  10. Aug 18, 2011 at 8:56 AM
    OZ-T
    Peter North
    British Columbia
    I didn't say I had yet , but under heavy loading , I'm wondering if the factory bumpstop is tall enough or whether it needs ti be taller
  11. Aug 18, 2011 at 12:36 PM
    OZ-T
    Peter North
    British Columbia
    Anyone else care to add anything ?
  12. Aug 18, 2011 at 4:42 PM
    OZ-T
    Peter North
    British Columbia
    After work bump
  13. Aug 18, 2011 at 4:49 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    just get rear airbags instead
  14. Aug 18, 2011 at 4:52 PM
    OZ-T
    Peter North
    British Columbia
    Instead of extending the bumpstops ?
  15. Aug 18, 2011 at 5:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont see how it would hurt anything using the factory stops, but I havent run a Dakar pack with a load.
  16. Aug 18, 2011 at 10:58 PM
    OZ-T
    Peter North
    British Columbia
    bump
  17. Aug 19, 2011 at 7:32 AM
    OZ-T
    Peter North
    British Columbia
    What he said ^^^
  18. Aug 19, 2011 at 7:42 AM
    PreRunner03
    PreRunner03 Hail State
    03 PreRunner Double Cab TRD
    Get some ride rite air bags. Firestone makes them for heavy loads and towing. Sounds like what you may need. Look into it.
  19. Aug 19, 2011 at 7:49 AM
    97yota4wd
    Eric
    Mesa, AZ
    i think if you needed to extend your bumps dakar would say something?
  20. Aug 19, 2011 at 8:09 AM
    OZ-T
    Peter North
    British Columbia
    For those of you suggesting airbags , you mean to run the Dakars and airbags ?
