Should I get a 2017 or a different year 3rd gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jcamasta, Feb 9, 2022.
  1. Feb 9, 2022 at 9:59 AM
    Jcamasta
    Jcamasta [OP] Member
    2012 Tacoma sport
    Hello everyone… I currently have a 12 TRD sport and looking at a 17 to get into. I know there have been numerous issues with these main being the transmission which some have issues and some do not. Does anyone know if at this point in time does Toyota have the correct reprogram to fix this issue for good? Any feedback on this or any other problems with the 17’ would be greatly appreciated! Should I get this year or a different year. Trucks sitting on the lot for 29,000 with 84k miles on it. Which is a lot cheaper then any others I’m seeing. Thanks
  2. Feb 9, 2022 at 10:10 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    I won't tell you to get it or not. I do like the versions without the pre-collision warning and lane depart for simplicity and just leaving me the (*&^ alone when I drive. Are there issues? Sure - it is the second year of a new model. The critical stuff should be warranty or NTSB items.
    Crank position sensor recall. (ensure it is done)
    Third brake leak light recall. (ensure it is done)
    Frame rust recall. (ensure it is done)
    Rear end howl. (turn the radio up louder)
    Driver door seal kazoo. (turn the radio up louder)
    Flash the transmission with new program. (good to do, but better if you do an OV Tune ECM flash as well)
    Body mounts by radiator clunk. (easy DIY when you feel like it)
    Truck needs a lift / sliders / lockers / bigger tires / body mount chop. (go drive it and enjoy it, if anything doesn't meet your needs then modify otherwise just save your money because the truck is very capable as is)
    908tacoma, 44-16 Taco and eurowner like this.
  3. Feb 9, 2022 at 10:21 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Do not lug the engine RPMs like your 2nd Gen! That will cause the transmission to shift differently when you don't want it to shift.
    Use "S"equential Mode and ECT. The 3rd Gen V6 makes HP and torque at higher RPMs.
    The transmission is not the problem. The Toyota 3rd Gen ECM/PCM tune is the problem. Get an aftermarket Local tune first.
  4. Feb 9, 2022 at 10:28 AM
    dan33410
    dan33410 Well-Known Member
    2020 Quicksand TRD Off Road
    2020 and newer has power driver's seat (common complaint for 3rd gen is the seating position), and an updated touchscreen headunit that includes Android Auto and Apple Carplay. Factory e-locker equipped trucks have a larger rear diff iirc...
    pltommyo likes this.
  5. Feb 9, 2022 at 10:29 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    you can turn off all the safety stuff if you want...
  6. Feb 10, 2022 at 6:05 PM
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    I have a 17 Sport. It’s been great. (104K miles on it).
    The only complaint is the anemic shifting. (I don’t have a tune yet like most - but even people with 2022s are getting tunes for the shift patterns. For me it drives fine. I drive in S4 a lot around town, and S5 on interstate unless I’m cruising long flat stretches.
    Update to latest software, drive with ECT mode on, if you don’t like it …get it tuned (many recommend KDMax now).
    It has Entune 2.0. I think 20+ has the newer with Apple Car play which I do kind of envy.
    Other than that it’s the same truck. If it has a clean carfax and the deal is good - buy it.
    Junkhead and PapaRee like this.
  7. Feb 10, 2022 at 6:40 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I have an 08/2017 built TRD Sport DCSB with 6MT. I have had no recalls. No issues. It has been a fantastic vehicle. I currently have just over 61,000kms of daily driving. I am very happy with my choice.
  8. Feb 10, 2022 at 6:46 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Nothing wrong with the transmission, drive it like a 2 stroke and your good.
  9. Feb 10, 2022 at 10:00 PM
    Darksport
    Darksport Well-Known Member
    Jake
    NE Ohio (Cleveland)
    2017 Black Tacoma TRD Sport 4x4
    33” BFG Ko2s,16” Method NV wheels, CMC, King 2.5 Remote Reservoir, Baja Kits UCAs
    I’ve got a 17’ 4x4 sport with 70k on it. It’s been a great truck. It’s anemic at best if you don’t use ETC though. I’ve made it my habit to just hit the ETC button as soon as it fires up. As others have stated I’m sure a tune would solve this issue. Other than that the trans has been trouble free and reliable, as well as everything else on the truck. I drove cross country, Southern California to Cleveland, towing a large uhaul trailer in 3-1/2 days going 80mph most of the time. I was not nice to her. But she got me to my destination without a hitch. Love these trucks!
  10. Feb 10, 2022 at 11:36 PM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    Ive got a 17' DCSB. They have done a few recalls, just like all the years pretty much. I was disappointed with the power when I got it, but I had one of the tunes done on it and it is crazy responsive now. No big issues aside from the charcoal canister acting up, but thats not a 17' thing. It can and probably will happen to most years.
    I like mine. Compared to the 91, 02, and 08 that Ive had, they seem to get more doo dads with each new model, but less reliable. Trade off I suppose.
  11. Feb 10, 2022 at 11:48 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Check the production date. If late 2017, buy it. Also check if ECU was updated to later version.
    Later 2017 is a golden year...
  12. Feb 11, 2022 at 1:12 AM
    tonestar
    tonestar Well-Known Member
    Anthony
    NY
    2015 Taco 4x4 V6
    $29,000 seems steep for an 84k mile 5 year old tacoma. I would drive your truck longer and save another $8,000 to cover the cost difference between new. You want a 5 year old truck with almost 100k miles for 25% off sticker price? No thanks. 2 years ago new tacomas were 10-15% off MSRP off the lot. Wait for new prices to drop, or don’t buy yet.
    Duckinatruck, Junkhead and coma toy like this.
  13. Feb 11, 2022 at 4:25 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Not really, unless you want to see the PCS OFF light illuminated all the time in the dash!
    Junkhead and Montana_Actual like this.
  14. Feb 11, 2022 at 5:06 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    I traded my 12 for my current 17. No issues *knock on wood*. I was unsure before purchase but now I know it was a good decision. I never looked back. Really love this truck :thumbsup:
    FishnTx, shakerhood and Junkhead like this.
  15. Feb 11, 2022 at 5:22 AM
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    man look around. 3 weeks ago i got my 2019 DCSB trd sport 2wd with 23kmiles for 33k and this was in the tampa bay area. i know it depends on the state you are located but there are still some dealers with no mark up. and at 29k you can even buy a new truck if SR/SR5 is not a problem
    Junkhead likes this.
  16. Feb 11, 2022 at 5:54 AM
    networkraptor
    networkraptor Well-Known Member
    2023 NBM ORP
    I went from a 2017 to a 2021. The 2021 feels more sorted out... steering and suspension felt more compliant. Also, better seats and head units.
  17. Feb 11, 2022 at 6:05 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    I would recommend looking at new in that price range. A brand new 2022 TRD Off Road can be had at my dealer for $36k. So for an extra $8k you get back 84k miles, 5 years back, a factory warranty, power driver seat, etc. To me, that seems like a pretty solid deal.
    You could also go the SR5 route and save a few thousand. Unless you really want the hood scoop (or rear locker on the OR) or MT, the SR5 is probably better value.
  18. Feb 11, 2022 at 6:14 AM
    klatekin
    klatekin Active Member
    2017 MGM TRD OR 6MT
    Is it a TRD Off-Road or Sport? Auto trans? $29000 seems pretty good. All the ones listed around me want $34000+
  19. Feb 11, 2022 at 6:16 AM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    I remedied the seat position issue with seat-jacks... so there's a way around that problem.
  20. Feb 11, 2022 at 7:36 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Get a pre Covid 2019 and put a radio in it. You’ll be ecstatic.
    Koolbreeze7 and Junkhead like this.
