should I get a new o2?
Discussion in 'Performance and Tuning' started by ETaco23, Mar 15, 2009.
  1. Mar 15, 2009 at 6:16 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Im ganna be going to the dealer tomarrow to get new denso plug wires, and was thinking of seeing about a new o2 A/F sensor. Bc of my verry crappy gas mileage, and rough idle. Should I?
  2. Mar 15, 2009 at 6:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you dont have a cel..........nothing likely wrong with the o2 sensor. yoiu can always try if you must tho.
  3. Mar 15, 2009 at 6:35 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    I wouldnt unless that cel is coming on try just the wires first
  4. Mar 15, 2009 at 6:39 PM
    ETaco23
    Evan
    PNW
    Alright. But I know of a couple people that haven't had a CEL, and were getting 12-14mpgs. And as soon as they got a new sensor it jumped back up to 19-20. But I will try wires first see what happens. Maybe clean my TPS and then check my mpg's. But if it doesn't get better, I think I should change my o2.
  5. Mar 15, 2009 at 7:11 PM
    98tacoma27
    Ben
    Not Beech Creek
    O2 sesnro shouldn't give you bad gas mileage. It just monitors the CAT effeciency. The AFR sensor will be the one to change.
  6. Mar 15, 2009 at 7:30 PM
    ETaco23
    Evan
    PNW
    Thats the one Im talking about! If it was going bad, could it also give me a rough idle at stop lights in gear? Almost like it is running lean.
  7. Mar 15, 2009 at 7:40 PM
    98tacoma27
    Ben
    Not Beech Creek
    I have never heard of an AFR causing a rough idle.
  8. Mar 15, 2009 at 7:55 PM
    ETaco23
    Evan
    PNW
    K, But If my mpg's dont get better. My next geuss is, faulty A/FR sensor. I think I should replace it anyways. Going on 110K miles!
  9. Mar 15, 2009 at 7:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    it cant hurt to replace it.
  10. Mar 15, 2009 at 7:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    Is there two on the V6?
  11. Mar 15, 2009 at 7:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    1 in front of the cats, and 1 after them. Both sides for a total of 4.
  12. Mar 15, 2009 at 8:03 PM
    98tacoma27
    Ben
    Not Beech Creek
    Thats what I meant, two afr's and two O2's.
  13. Mar 15, 2009 at 8:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah, gotcha.
  14. Mar 15, 2009 at 8:05 PM
    98tacoma27
    Ben
    Not Beech Creek
    Take the tin foil hat off so you can read my mind...........:D
  15. Mar 15, 2009 at 8:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oooo....Sorry....Forgot that thing was on....
    Ok.....thats better.....wait.........wait....HEY!!!!!:eek:
    Hats going back on!!!!!
  16. Mar 15, 2009 at 8:08 PM
    98tacoma27
    Ben
    Not Beech Creek
    :rofl: :rofl: :rofl:
  17. Mar 15, 2009 at 8:49 PM
    ETaco23
    Evan
    PNW
    So when I replace my sensors. should I replace both AFR sensors?
  18. Mar 15, 2009 at 9:01 PM
    98tacoma27
    Ben
    Not Beech Creek
    Those sensors are $170 a pop from URD. Imagine what they will cost from the dealer. That's a pretty expensive investment for an unknown cause. You should be throwing a code if one of those is bad.
  19. Mar 15, 2009 at 9:12 PM
    ETaco23
    Evan
    PNW
    Yep! I know. I wont replace them, yet. I know a place were I can get them for 140. But thats still spendy! I just was wondering, when or if I do change them, should I change both AFR sensors?
  20. Mar 16, 2009 at 5:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your not throwing a code, your gonna have to replace both. Right now, your kinda chaseing a gost.....not knowing exactly what the issue is. Try the wires first and see what that does for ya.
