should I get a new o2?
Discussion in 'Performance and Tuning' started by ETaco23, Mar 15, 2009.
  1. Mar 16, 2009 at 5:54 AM
    98tacoma27
    Ben
    Not Beech Creek
  2. Mar 16, 2009 at 11:50 AM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yes Master....:D I just got my wires and am waiting for the engine to cool down so I can put them on. Cross my Fingers!
  3. Mar 16, 2009 at 11:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    *..........crossing fingers..................*
  4. Mar 16, 2009 at 12:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    *....................and toes for good measure...............*
  5. Mar 16, 2009 at 1:08 PM
    ETaco23
    Evan
    PNW
    Yippy!!!!!! My rough idle low RPM is better! it at 750 and only drops to about 650. before it would drop to close to 500-550 and be rough. So I hope it stays like this.:D
    I also took a look at the TPS sensor and did a little adjustment. theres some slack in the screw holes, and I moved it counter clock wise and tightened it. So which ever one helped, I dont know, probably both. But Im Happy!:woot::bananadance:
  6. Mar 16, 2009 at 1:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    It should stay at 750, in park/nuetral.
  7. Mar 16, 2009 at 1:14 PM
    ETaco23
    Evan
    PNW
    Yep! it does. Im talking about when im driving and stop at a light or stop sign.
  8. Mar 16, 2009 at 1:18 PM
    98tacoma27
    Ben
    Not Beech Creek
    Ok. That is not quite normal but better. Like you already said. HAHA. It should try to correct itself and idle up a little more. Have you done a seafoam treatment?
  9. Mar 16, 2009 at 1:21 PM
    ETaco23
    Evan
    PNW
    yeah, the last time I did was maybe a month ago.
  10. Mar 16, 2009 at 1:25 PM
    98tacoma27
    Ben
    Not Beech Creek
    Have you changed plugs yet? (don't remember if you said that or not)
  11. Mar 16, 2009 at 1:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    650 sounds about right for the first gens, at a stop, in gear and foot on the brake. The second gens will drop to near 500, or there about.
  12. Mar 16, 2009 at 1:27 PM
    ETaco23
    Evan
    PNW
    yeah i did. and gapped them.
  13. Mar 16, 2009 at 1:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to hear its better! I would bet it was the wires, but regardless, Its better! :)
  14. Mar 16, 2009 at 1:28 PM
    ETaco23
    Evan
    PNW
    all i gotta do now is check my mpg's to see if they've improved. im ganna be pissed if i still am getting 12-13. Especially after doing Seafoam, Plugs, Plug wires, Fuel filter, clean MAF and TB, New PCV. I think thats it so far...
  15. Mar 21, 2009 at 4:50 PM
    #35
    ETaco23
    Evan
    PNW
    Well guys! I just filled up and sure enough Im still getting like 13mpg's. I dont have a heavy foot and I drive perty good. But is my next thing to do to try and improve it is get a new A/F sensor? Or what?
    I know I should be getting alot better, even with my setup.
  16. Mar 21, 2009 at 5:13 PM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Are you takeing into account the larger tire size? The tires you are running are 7.1% larger than the stock ones. Add 7.1% to your odo reading, then divide by the number of gallons used. Im betting that after you add the correct amount for speedo error, and extra drag from the lift and larger tires, you may be right in line with what to expect for fuel econ.
  17. Mar 21, 2009 at 5:16 PM
    #37
    ETaco23
    Evan
    PNW
    ok, ill try that and see what i come up with.
  18. Mar 21, 2009 at 5:20 PM
    #38
    ETaco23
    Evan
    PNW
    Ok, now that puts me closer to 15mpgs. But thats not acounting for the spedo being off and drag.
  19. Mar 21, 2009 at 5:25 PM
    #39
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Speedo being off doesnt matter. Use the ODO. 15 sounds about right inline with lifted 3.4 first gens..depending on how you drive.
  20. Mar 21, 2009 at 5:31 PM
    #40
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    On the 1st gen V6 Tacos there's one sensor before the cat (AFR one) and one after the cat. Total of two, not four. Trust me I been chasing those damn things in my 02 for the past month.
